Vacuum leak check with water?
Old Dec 24, 2010
rhymeboy89's Avatar
rhymeboy89 is an unknown quantity at this point
I heard from some guy at pepboys that you can check for a vacuum leak with water instead of carb cleaner. I would definitely rather do it with that because I read that the carb cleaner could become flameable and toast the car. Trying to see if it is true that you can check with water and if someone can post a pic or link me to somewhere showing where I would spray the water or carb cleaner to check for leaks.
Old Dec 24, 2010
BlueEM2's Avatar
Whachya lookin at?
Re: Vacuum leak check with water?
I wouldnt use water, you could hydrolock the engine if you use too much... Carb cleaner is desgined for that specific area of the engine why not use it? Spray the joints around the throttle body, if you notice RPM changes when you spray a certain area you have found your leak.
Old Dec 24, 2010
rhymeboy89's Avatar
hate to be a bother but i dont understand what you mean by joint of the throttle body. Is there a picture u could point me too? Don't want to try anything without being absolutely certain what I am doing.
Old Dec 25, 2010
BlueEM2's Avatar
Whachya lookin at?
Below your air box is the throttle body with lots of little joints for various reasons... There is a picture but it being christmas i just dont have time to dig it up... ill post up here again when i'm not so busy.
dennis123
May 3, 2015 03:14 PM
HX
Dec 28, 2001 10:04 AM
Micks2K1
Dec 6, 2001 07:09 PM
delacampos
Nov 7, 2001 09:18 PM
GoofyLogicInc
Oct 25, 2001 09:50 PM
