2003 Hybrid overheating. Cannot find reason.
Old Sep 21, 2010
jasonkoller's Avatar
jasonkoller is an unknown quantity at this point
On Sep-16 my hybrid started making grinding noises and went to half power.
The temperature was high and the OBDII reader gave me P0335 [Crankshaft Position (CKP) sensor circuit, no signal]
I bought a new TDC Sense and replaced it today as well as topping off my fluids.
The coolant had gotten low.
After a few miles of test driving,
The check engine light came on and the car had the same symptoms.
This time the OBDII reader came up with
P1449 [Battery Module Overheating,Battery Cell Overheating, Battery Module Individual Voltage Input Deviation, Battery Module Deterioration, Battery Module Deviation]
P1600 [TCM Internal Watchdog Operation]
I doubt the battery would cause the noise.
I'm leaning more towards to Transmission Control Module.
What is the TCM and where is it located?
Old Sep 22, 2010
Update
Alright,
I've isolated it to the the radiator fan.
It seems that causes the overheating which causes all the other stuff.
I tested all relays and fuses.
They all work.
I tested the fan motor.
It works.
I tested the voltage to the fan.
it reads 0.
Old Sep 22, 2010
Re: 2003 Hybrid overheating. Cannot find reason.
I got the fans working,
And double checked all my fluids,
But it still overheats.
It didn't throw any OBDII codes this time,
But I suspect that's because I got home before it did.
Any ideas?
Old Sep 22, 2010
Camden's Avatar
Camden is an unknown quantity at this point
any chance its a thermostat issue?
S.Klinck
Feb 10, 2016 02:19 PM
supra8311
Sep 16, 2015 02:07 PM
S.Klinck
Jun 11, 2015 10:27 PM
carid
Apr 30, 2015 07:00 AM
dooner24
Apr 14, 2015 07:51 PM
