need some help new member
im a new memeber and was looking for someone to point me in the direction for some new door inserts and maybe a dashkit with a variety of colors to choose from..
i own a 2003 honda civic coupe lx
Re: need some help new member
the door inserts you can make yourself, just go to any fabric store and find something you like. cut it out from the old fabric insert, and glue it in. dashkits you can either go oem (www.handaaccessories.com) or check ebay for more choices.
http://daddyscaraccessories.rpmware.com/
Lotsa interior stuff there, too.. Cloth door panel inserts, headliners, sun visor wraps, a/b/c pillar wraps
well most people use spray adhesives in a can, but if the fabric is too thin it will bleed thru. make sure it has a good backing. i used double sided sewing tape but some parts are starting to come off from the extreme heat (same happened using spray glue tho). next time i fix it i will try and find a higher strength tape.
junkyardguy
Sep 2, 2015 06:07 PM
