Does not start on the first try.
Old Jun 20, 2010
sc3's Avatar
sc3
sc3 is an unknown quantity at this point
Hi,
Lately, my car will not start on the first try in the morning. I turn the keys for a few seconds (2-4 seconds), if it does not start, I turn back the key and try again, the car starts. Any ideas if this is a battery change or a serious problem?
6 months back I took the car for a oil change @ Midas and the tech told me that the battery needs replacement and so does the brakes. Since brakes meant safety, I immediately took it to a different shop to replace the brakes (did not feel like taking Midas brakes). The person there was a bit surprised that I went in for a brake change when I told that the brakes were not making any grinding sounds (but I went ahead with the replacement anyways, as it was about 9 years since I bought the car -- low use).
Given that experience, I did not think too much about my battery change (everything radio, lights worked perfectly), but I started to get a nagging doubt every since that I need to replace the batteries. Since then I had been on 7 day vacation for the car (i.e no use) and the car sprung up nicely, and the latest oil change with Firestone, the tech did not complain about battery charge (although he complain about air filter replacement).
But a little since then my car does not start at the first instance, it almost always takes two tries (I do not try cranking for more than a couple of seconds). Any suggestions if it is the battery, or is it something worse.
I also have the key icon flashing (I tried the seldom used spare key too, so the problem is likely not at the key end).
I hate to admit it, but I not too mechanically inclined. Just want to get a good idea of what might be wrong, so I can plan accordingly.
danace99
23
Jun 28, 2015 08:49 AM
ALLMAN
Engine DIY
73
Jan 19, 2009 11:21 PM
black2k1vtec
Dec 6, 2001 09:49 PM
aznboy808
Bolt-on Engine Performance
Dec 1, 2001 04:10 PM
supercivic01
South
Nov 30, 2001 11:27 AM
