Electrical Issue
Old Apr 27, 2010
JKoffler44's Avatar
JKoffler44 is an unknown quantity at this point
Electrical Issue
My 01 Civic EX has been having an issue where the radio will shut off, the ABS, SRS light come on and then everything is instantly back to normal. The car doesn't actually shut off. I brought it in to the dealer to get the diagnostics done. After $140, they tell me they can't find the problem. My car is just getting old they said. May be time to consider junking it! Then told me to get $1500 worth of other jobs done....
Any ideas? I've done google searches and came up with the alternator or the ignition switch.
Old Apr 27, 2010
BlueEM2's Avatar
Whachya lookin at?
Re: Electrical Issue
Check your grounds. Make sure they are all clean and grounded properly under the hood.
Old Apr 29, 2010
JKoffler44's Avatar
Thanks. I just got the car back from the stealership last night. First thing I did was open the hood to check the grounds and realized that the positive battery cable was loose. Didn't take any effort to remove it from the terminal at all. Hopefully that is it, since I've read others with similar issues. I can't wait to call the dealership back and bitch them out. For $130, you would think they would have caught that!
Old Apr 29, 2010
BlueEM2's Avatar
Whachya lookin at?
Yea, another lovely dealership story. Hopefully it's fixed good luck.
Old Oct 25, 2010
entensity's Avatar
entensity is an unknown quantity at this point
I have a similar problem with my 02 Civic HX
Out of no where, about 1-4 times a month my car will randomly cut off. Here is what happens:
I will be driving normally and all of a sudden hear my radio slightly cut out for a split second... when I hit the brake pedal or turn on my heat or AC the car cuts out for a second... the guages go down, the SRS light comes on and my radio cuts out, the head lights dim.. after that second the car is back to normal and it may happen a couple times in a 2 minute period but then goes away for a few weeks.... I replaced the alternator thinking that was the problem, didn't change anything. Im stumped.
Old Oct 25, 2010
Mad Dog Tannen's Avatar
I am stumped too.
FYI: You might want to start a new thread. Asking a new question in someone elses thread can be considered "thread jacking". There is a thread that covers forum etiquitte that you might waant to read.
...Oh and welcome to the furum.
Old Oct 27, 2010
entensity's Avatar
Sorry about that, just thought we could tag team the problem, if I come up with anything I will send you a message asap... thanks for the heads up.
h4ldol
Jun 3, 2015 03:26 PM
juror
May 26, 2015 06:35 PM
WLakers
May 4, 2015 06:23 PM
mohawkboom
32
Oct 9, 2006 02:49 PM
mohawkboom
50
Apr 21, 2002 06:12 PM
