sent + trigger thru alarm parking light wire now no lights :(
Old Feb 21, 2010
racermp's Avatar
racermp is an unknown quantity at this point
hey all, need urgent help please. i'll paypal 5 bucks if you solve this prob.
so i was wiring up a aftermerket keyless and i sent positive thru the alarm harness blue wire for parking lights. the wires heat up and now the lights don't turn on.
i did run negative constant now thru the alarm harness on the blue wire and all lights work but stay on. how can i fix this? i need lights back asap.
ANY HELP please.
update : FIXED!! thanks all
Old Feb 22, 2010
racermp's Avatar
Re: sent + trigger thru alarm parking light wire now no lights :(
ttt any help please
Old Feb 22, 2010
well if the wires got hot, there is no fix other than to replace the wire, or it may have even damaged the alarm itself.
Old Feb 22, 2010
racermp's Avatar
hey, thanks for the reply.
the alarm works fine, tis' a lx so it didn't come with factory alarm. if i run a negative current on the same blue wire on teh factory alarm harness, then the headlights/ parking lights work.
does anyone have a wiring diagram from headlight switch or know the wires i can test on the headlight switch?
thanks all
Old Feb 27, 2010
racermp's Avatar
ok took it back to the dealer, all fixed
werdnahall
May 17, 2015 11:37 AM
supercivic01
South
Nov 30, 2001 11:27 AM
AzNmiKex215
Nov 29, 2001 08:02 PM
NukeSilo
Nov 20, 2001 05:17 PM
klam
Nov 16, 2001 03:36 PM
