Sunroof drain??
Old Jan 21, 2010
Xplod590's Avatar
Xplod590 is an unknown quantity at this point
Sunroof drain??
My drivers side floor board is getting soaked when it rains. I gotta start somewhere to find this thing. Are thier a certain stop that the tubes for the sunroof leak or that i need to check first?
Old Jan 21, 2010
Re: Sunroof drain??
there are four drain tubes, two go back in the trunk, two go towards the front fenders. pull off some of the plastic paneling pieces like the kickpanels and you will see the tube. sometimes it comes loose and just drains into the car floor.
Old Jan 21, 2010
BlueEM2's Avatar
Whachya lookin at?
Re: Sunroof drain??
Mine does the same thing... hmm... I have no idea what it could be though.
Old Jan 21, 2010
Xplod590's Avatar
Re: Sunroof drain??
K thanks agian Gearbox the first sunny day i get ill see what i can find out and let ya'll know.
Old Jan 25, 2010
Xplod590's Avatar
Re: Sunroof drain??
I need some more help, I just got done lookin at my drain tube for my sunroof and it works fine. the foam that is around the tubing is not wet at all, the sides (going up towards the door sills & going from the floor to undernieth the center console) of my carpet is not wet either. My doors nor the dash is wet when it rains so thats why i am confused. where do i go next? Any help would be great.
Old Jan 25, 2010
Re: Sunroof drain??
can you see water coming in anywhere? window seals, door seals, etc? where exactly is wet? you may need to rip up some of the carpet to get a good idea.
Old Jan 25, 2010
Xplod590's Avatar
Re: Sunroof drain??
No I dont see where it could be coming from. i wanted to check to see if their was a common place for the water to come in. i going to take some carpet up and probably redo it since its been getting soaked this past weekend. Ill check it out and see if i can find out anything and let ya know.
Old Feb 10, 2011
BADAPL's Avatar
BADAPL is an unknown quantity at this point
Re: Sunroof drain??
I just got done fixing this exact same issue on my coupe. It took me forever to find it. Thought it was the windshield , Cowel , Firewall , ect.. Finally after removing the headliner and doing some test with a water bottle I found that the drain tube from the sunroof on the front drivers side was draining directly onto the floor. Its located on the driver side behind the cruise control box and mounting bracket. The tube exits from the body then connects to a rubber tube that goes back through the body and drains behind the fender. This is the stupidest thing I have ever seen Honda do. Why go through the body back into the cab and back out through the body makes no sense!!! I have since put a hose clamp ($0.35 fix ) on the hoses to keep them together. Hope this helps. I will update with the other photos to show drain spot and hose clamp fix.( I have uploaded a pic here... http://whateversales.com/badapl/drain%20tube.jpg )
SammySC
121
Apr 7, 2017 07:43 PM
Munzy
21
Oct 7, 2015 07:48 AM
Raiool
Oct 1, 2015 10:42 AM
jackoncruzpr
Sep 29, 2015 07:59 PM
EM2661
Sep 11, 2015 06:01 PM
