Seriously...nobody can help?
Old Jul 1, 2009
rbragan's Avatar
rbragan is an unknown quantity at this point
I posted this thread the other day but didn't get one response so I am going to try again...
I have a 2002 EX that starts fine but as soon as I come to a stop the engine wants to die. If I give it gas it will bog down and almost cut out but never actually does. If I keep pumping the gas it will eventually come back and will run fine until I come to a stop again. This continues until the engine gets good and hot. Anyone know what might be causing this to happen? I talked to a mechanic and he thought it was the distributor cap but now I just read that this model doesn't have one...
Anyone have any ideas?
Old Jul 1, 2009
Tragedy's Avatar
skate or die
Re: Seriously...nobody can help?
IT could be a number of things. Check the spark plugs, fuel injectors, idle, fuel pump, and throttle cable. It sounds like a bad air fuel mixture, but it could be a faulty part too. Take it to a auto repair shop.
Old Jul 1, 2009
bachlava7's Avatar
bachlava7 is an unknown quantity at this point
Yeah, I agree with Tragedy. Take it to the shop soon. Can you hear if your engine is pinging at all?
-bachlava7
Old Jul 1, 2009
um yeah find a different shop that actually knows the car. could be all sorts of things
-rough idle caused by dirty intake system (throttle body, iac valve)
-spark plugs misfiring
-clogged fuel injectors
-fuel pressure too low (check pressure and possibly replace fuel pump)
-clogged catalytic converter
is ther check engine light coming on?
Old Jul 1, 2009
Old Jul 1, 2009
rbragan's Avatar
Thanks for the responses guys. Yes, the check engine is coming on (although not all the time) and I have not heard any pinging from the engine. I guess I will take it to a (different) shop but it's probably worth doing a couple of the low-cost options (changing the plugs, clean the fuel injectors, etc.) first right? Can anyone confirm that the 2002 does not have a distributor cap?
Thanks again.
Old Jul 1, 2009
quietride's Avatar
quietride is an unknown quantity at this point
Yes, no distributor so no cap.
