Problem after cold start up
Old May 28, 2009
CrazyCakes's Avatar
CrazyCakes is an unknown quantity at this point
So I have a 2002 civic ex coupe 5spd and lately I have an issue with the car right when I start it. Basically it starts fine then once I begin to move the throttle response completely goes away and the car stumbles, it wont actually die just the rpms fall to around 500ish. If I push the clutch back in it will pick the rpms back up but it wont always. Generally it does this 3 or 4 times or until the car has run for around a minute or 2. It normaly only does it when the engine is cool (ambient) but sometimes will do it when the car has just sat for a few minutes.
It will also do this if the car is just sitting idleing and not being driven. Again rpms fall and the car stumbles, after it shutters for a few seconds it runs fine.
I'm at a loss at this point I dont have a fancy scan tool to check that everything is functioning correctly. I have to assume its a sensor of some sort but they are expensive and I dont want to throw parts at it.
Old Jun 9, 2009
batman900's Avatar
batman900 will become famous soon enough
Re: Problem after cold start up
bump i get this prob sometimes also
Old Jun 17, 2009
CrazyCakes's Avatar
Is your CEL on? I just had my CEL come on and its throwing a code for cat inefficency. I dont know if this problem could be from a clogged cat or something but its getting worse.
Old Jul 1, 2009
CrazyCakes's Avatar
Ok so I cleaned the TB, IAC and EGR valve with some carb cleaner and that seems to have fixed the problem. I will keep you posted if something changes
Old Jul 1, 2009
that should fix it. dont forget to do the ecu reset and idle learn.
sharp66
31
Jun 12, 2022 08:45 AM
TXcivic2001ex
Air Conditioning
23
Jul 20, 2020 07:27 AM
crowtoo
May 11, 2015 06:50 PM
Ninetyatecivic
May 9, 2015 07:48 PM
black2k1vtec
Dec 6, 2001 09:49 PM
