Valve Guide/Seal Replacement
Old May 5, 2009
utahbmxer's Avatar
utahbmxer is an unknown quantity at this point
So my '01 4dr 5spd has been having oil spitting out the exhaust for the past 6+ months. It started when the valve clearance on cylinder#2 got way tight (like 3-4 full turns on the tappet) and made my engine run real rough and pop codes. After pressure testing I found there was something with #2 so I performed a valve adjustment and re-learned the idle. The engine ran like new, although the oil issues still remain. It is spitting oil out my exhaust (covers the rear bumper and exhaust tip). I have to add somewhere in the neighborhood of 1qt every oil change or so.
To my question: what do I need to do to replace the valve guide seals and possibly the guides? Do I need to completely yank the head or can this be done on the engine? I am pretty competent when it comes to mechanics, I have just never done valve/head work before and wondering if anyone has any insight to this problem. I assume either the jack-wad that did my timing belt either short-cutted the job; or with the valve getting that far to tight, something might have got damaged from ignition back-pressure
Short history of engine:
Has roughly 159,000 miles
Been mostly on top of oil changes, running 5w-20
Timing belt broke a little over a year ago, (had head supposedly milled/reworked as some valves broke)
Supramk3
May 11, 2015 07:55 PM
crowtoo
May 11, 2015 06:50 PM
JohnnyBxo
16
May 9, 2015 05:53 PM
thesushiboy
Apr 12, 2015 02:54 AM
ALLMAN
Engine DIY
73
Jan 19, 2009 11:21 PM
