Given these faults of this Civic, how much can I knock down off the asking price?
Old Mar 15, 2009
fantasyvn's Avatar
fantasyvn is an unknown quantity at this point
Hi all, I'm new here and would be grateful for your help with buying my first car.
I'm considering this 2003 Civic hatchback, which is selling for £4900. However, according to its latest MOT advisory notice, there are some faults:
Advisory Notice issued
Nearside Front Direction indicator slightly discoloured (1.5.A1d)
Centre outer cover insecure Exhaust has part of the system slightly deteriorated (7.1.1a)
Offside and nearside front lower wishbones [front] bushes tearing out
I also noticed that this car has failed all of its 3 tests - although it got passed during its retests. What is your opinion?
For those who have more time, I list below the previous test results:
My sincere thanks,
First test:
Certificate issue refused (Fail)
Reason(s) for refusal to issue Certificate
Offside Rear 40kgs off drag Rear brake binding (3.7.A.5a)
Nearside Front Windscreen wiper does not clear the windscreen effectively (8.2.2)
Offside Front Windscreen wiper does not clear the windscreen effectively (8.2.2)
Offside Rear Brake disc(s) excessively scored (3.5.1h)
Offside Rear Brake disc(s) excessively pitted (3.5.1h)
Offside Rear unable to check wheel bearing Rear brake binding (3.7.A.5a)
Rear brake application uneven (3.7.A.5c)
Rear brakes release unevenly (3.7.A.6)
Nearside Rear Brake disc(s) slightly scored (3.5.1h)
Nearside Rear Brake disc(s) slightly pitted (3.5.1h)
Nearside Front Macpherson strut has slight play in the sliding bush or gland (2.5.B.1b)
Offside Front Macpherson strut has slight play in the sliding bush or gland (2.5.B.1b)
Nearside Front Brake pad(s) wearing thin (3.5.1f)
Offside Front Brake pad(s) wearing thin (3.5.1f)
Handbrake has very little reserve travel left
Rear wiper blade badly torn
Second test: on the same date
Certificate issued (Pass)
Rear wiper torn
Third test (the following year)
Offside unable to check wheel bearing Rear brake binding (3.7.A.5a)
Nearside Front Lower front Suspension arm rubber bush deteriorated but not resulting in excessive movement (2.4.G.3)
Rear wiper badly torn
Fourth test (the same date)
Offside rear brake has a very slight bind
bsmiley
Apr 27, 2015 01:27 PM
GaryFishell
Apr 24, 2015 06:49 PM
Strychnine
Aug 15, 2001 07:07 PM
