help
Old Feb 12, 2009
itchoy's Avatar
itchoy will become famous soon enough
help
i got a problem with my doors(the driver side).when i close it it does not close fully..like its not align properly.when closing it still is not fully align with the body.is there any way i can fix this up?
Old Feb 12, 2009
Protan988's Avatar
Protan988 is an unknown quantity at this point
Re: help
Your going to have to be a little more specific. You probably have a bad hinge that needs to be replaced.
Old Feb 12, 2009
greeen01civic4d's Avatar
Re: help
need to adjust the striker, loosen bolts and slide it inward
Old Feb 12, 2009
Re: help
then reitghten bolts
Old Feb 12, 2009
itchoy's Avatar
Re: help
ah so thats how you adjust it...let me try it tomorrow..thanks guys
Old Feb 27, 2009
civic-king's Avatar
civic-king is an unknown quantity at this point
Re: help
if it is sagging, you can put a floor jack under the door and lift the vehicle slightly with the door. i'm not sure what "misaligned" means. the door can be misaligned in about 8 different ways...
