manual tranny kicking out of 5th gear
Old Feb 12, 2009
hypnotic7thgen's Avatar
hypnotic7thgen is an unknown quantity at this point
driving down the highway today at around 70 mph. and the transmission just kicked out of 5th into neutral. So, i put it back into 5th and seconds later same thing happened. first time this has happened so i'm not too sure if it's worn gear teeth or something in the shift linkage is broken or it's the clutch. any ideas?
Old Feb 12, 2009
greeen01civic4d's Avatar
Re: manual tranny kicking out of 5th gear
it happens, there is a tsb about this, its the 1 2 and 5 shift forks that need replaced
Old Feb 12, 2009
what is tsb?
Old Feb 12, 2009
technical service bulletin
Old Feb 27, 2009
civic-king's Avatar
civic-king is an unknown quantity at this point
fluid level can cause this issue too. check level, leaks, and axel seals.
97-DX-Lover
Jun 14, 2015 06:07 PM
lildoo
May 9, 2015 09:44 AM
dosmastr
May 5, 2015 12:19 PM
02Si
Dec 14, 2001 10:26 AM
Poysynfree
Auto Transmission failures
Dec 13, 2001 06:08 AM
