changing a clutch on a 2001 civic ex
Old Jan 30, 2009
stock03's Avatar
stock03 is an unknown quantity at this point
Question changing a clutch on a 2001 civic ex
I'm ready to start working on my car. Any advice for changing the clutch, or is it pretty much straight forward?
Old Jan 31, 2009
LemmieHill's Avatar
LemmieHill is a jewel in the roughLemmieHill is a jewel in the roughLemmieHill is a jewel in the rough
Re: changing a clutch on a 2001 civic ex
Its fairly easy. Just make sure to support your tranny when you drop it because you do not want to bend the input shaft. Make sure to resurface or get a new flywheel and pressure plate. Also dont forget to replace throw out bearing. When you go back together, you should not have to force it together. You dont want to mess the splines up if you force it.
Old Jan 31, 2009
stock03's Avatar
So far so good. But now I'm at the point where I need to remove the axles. Is there an easy way to remove the lower "A-arm" (not sure what it's called) without the Honda tool? Once I get the axles off, I should have the car up and running soon.
Also, I'll be getting a new clutch, pressure plate, and throw out bearing tomorrow.
Thanks for the help, I really appreciate it.
Old Feb 1, 2009
LemmieHill's Avatar
Im not to sure about those drive axels. A-arm or lower control arm but you should be able to remove with regular tools. Your best bet would be to get a bentley or hanes manual. If you are spending the money to get all that, get a better flywheel but you will need to resurface the OEM one if you do not get a new one.! And since your doing all this tranny work, you should flush it and put in some good synthetic tranny oil. Look at this pic. maybe it will help.
http://www.hondaautomotiveparts.com/...tcgry5=KNUCKLE
Old Feb 1, 2009
stock03's Avatar
Great picture/diagram! Thanks. I have plenty of tools, to include a sledge hammer (I used a sledge hammer taking off an A-arm before, but this Honda one looks kind weak, and I'm worried I'll bend it). And ideas how to separate the A-arm from the ball joint? Or just "tap" it until it pops out?
Again, thanks for your help!
Old Feb 1, 2009
stock03's Avatar
UPDATE:
Almost complete. First test drive tomorrow.
Old Feb 2, 2009
stock03's Avatar
It's finished! Runs like a champ!!!
Old Feb 6, 2009
LemmieHill's Avatar
How long start ton finish?
Old Feb 9, 2009
stock03's Avatar
About 10 hours. But I marked EVERY bolt with tape and amarker so I knew exactly where it went. This helped alot, because after this job, I didn't have any extra parts.
Old Feb 11, 2009
Protan988's Avatar
Protan988 is an unknown quantity at this point
Honda doesnt make synthetic atf.
mattdoc
Mar 14, 2017 12:10 PM
CapYoda
Nov 11, 2001 05:17 PM
Lightman
Nov 10, 2001 06:44 PM
liljoe
Nov 4, 2001 01:27 PM
HitlistCivic01
Oct 27, 2001 07:47 PM
