Does the 7th Gen Civic have an interference Engine?
I currently have almost 130k orginal miles and I was almost certain we had a non-interference engine, and I could just ride it out till the timing belt popped. But some guy at Tire Rack said his computer said it was an Interference Engine, and I checked this link at it says it's an interference engine.
http://www.gates.com/downloads/
I can't recall where I read/heard that it was non-interference, but I was positive it was.
Does anyone know for certain whether our engines are interference or not?
Thanks.
ps, yes I searched, found nothing.
Thanks.
Re: Does the 7th Gen Civic have an interference Engine?
Yes it's an interference engine. Change the timing belt now or wait until it breaks, then change the timing belt and a bunch of valves.
Prowlin' with a Purpose
its interference.. ALL honda engines have been interference as far as i know... whoever told you that needs to be smacked... cause if the timing belt breaks.. you might be ok... but more than likely you will need a new head after it breaks and possibly pistons...
It means that the pistons will interfere with the travel of the valves if the motor is spinning out of synch - i.e. the t-belt breaks and the crank spins at a different speed than the cam.
Why would you need a new head? That makes no sense. Identify bent valves, remove them, install new valves and seals, lap them in, job done.
spose you could go that route... but it usually ends up damaging more than id like to admit.. could get a used head i spose
Oh MAN!!! What the hell was I thinking!!
I bought the car almost 7 years ago, and my last car was an interference engine, and all I remember is I somehow found out it was a non-interference, and I was happy about that.
CRAP. I have 130k miles, and I drive a butt load every week. I need to get this thing changed before I bust up a lot of junk. Ahhhh I'm going to call my shop, but I don't know how I'm going to get around. lol
Thanks guys.
Thanks guys.
I know your sig says Trained Honda Technician, but again, your statements aren't making any sense unless you are just trying to get your service department more money from bigger tickets.
its actually sort of a twofold thing.. have you seen prelude pistons where the timing belt broke at 7k? i just make it a habit of doing worst case scenarios in the event of, i have seen damaged pistons, but you wont know til you pull the head off
Dude, I would replace time timing belt ASAP! I busted mine at like 133k miles last fall, it started clicking at a cold start-up a week before it snapped. I am still kicking myself for being so lazy, even know I got away fairly decent for what happened. I ended up breaking 8 of 16 valves, and after that was fixed some of the journal bearings went out as well. About $1,500 later it was all fixed, now I am having random misfires that may or may not be related. Don't chance it, you'll pay twice the money, or worse... be shopping for a new engine.. you could always get that K20 you've wanted.
Xuhme
21
Aug 7, 2023 03:40 PM
Rardon6thgenCiv
Apr 15, 2015 07:37 PM
