Window problem( didnt mean to post 2 times just found a better topic place)
So i am having problems with my passenger side front window and my rear driver side window... the front passenger side just seems to get stuck and i have to inch it down and then up to get it to close.. and the rear driver side wont work at all and i hear a crunching noise when i try to move it up or down.... so my question is wat needs to be fixed?
Re: Window problem( didnt mean to post 2 times just found a better topic place)
if you take off the door panel you can check out all the adjustment options for the window inside the door. there are to many to explain but you can figure them out with some tinkering around. it really is just a matter of putting them where you think they going to work.
how do i get the door off i know i gotta unscrew the 2 screws in the handle but then wat?
Prowlin' with a Purpose
the rear window regulator/motor assembly is probablly fubared.. and will probablly need to be replaced if its crunching
to take the front door panel off unscrew the door handle(the one that opens the door) and pop the clip off the little rod, then you pop the cover off the other handle(the one that has the power window switch on) and then there are 2 screws behind that, unplug the switch and once both screws are out, pull the panel off, there should be a few clips holding it in place, start from the bottom and work your way around and there is a plastic seal around the door.. carefully peal that back
