Clutch master cylinder
Re: Clutch master cylinder
You keep blowing master cylinders? Have you flushed the line and replaced the slave cylinder? Sounds like you have a pressure issue that's wearing out the master cylinder. Whether that's caused by a faulty slave (not likely) or a problem in the tranny I don't know.
How is the clutch engagement when it's working? Tranny make any funny noises?
new slave and lines. works fine then just blows for no reason. the last one blew after a whole day of driving on way home shifting into 4th. the first one blew after i parked it for an hour.
Then you've got a problem downstairs by the release fork is what it seems like. How is your pedal pressure? Was it doing this before you installed the new clutch and FW?
Sounds like something is fuxored on the release bearing side causing there to be too much pressure on the clutch system which is blowing your master cylinders. Might be worth popping the tranny off and having a look inside to see what's going on. What's your pedal pressure like?
Official Rattlesnake Hunter
you pressig the clutch "all the way" to the floor?
You should, i blew one because i kept pressing and releasing the cluch at different spots...
allways clutch at the same spot
just my experence with my blown master
Your clutch should not be extremely hard. Sounds like your release bearing is not installed properly or it's bad. Pull the tranny off and the take a look at it and reseat it if necessary.
mrohitredd
40
Sep 9, 2017 12:03 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
honda.lioness
Aug 6, 2015 11:58 AM
