Misfire codes
Old May 19, 2008
Silverstreak04's Avatar
Silverstreak04 is an unknown quantity at this point
Misfire codes
I have 5 misfire codes on my EM2 Cylinder 1 2 3 4 and then random misfire code. How do i solve.. also when i drive down the highway and cruise at 80, now when im try to pass 80 0r 90 with out stickin my foot all the way in teh throttle the car will sputter from richness but why is my check engine flashing... Can some one shine some light on the situation... cant figure it out... thank you
Old May 19, 2008
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
Re: Misfire codes
i had a misfire for two years...
turned out to be a bad head gaskett...
what makes you think your sputtering due to it being too "rich?"
my random guess is head gaskett tho...
Old May 20, 2008
FoSho's Avatar
FoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of light
Re: Misfire codes
^what he said...........headgaskets can cause this. I had this same code from my valve cover gasket tube seals leaking oil onto the plugs...they also caused misfires at highway speeds........easy fix for me though start w/ the easy ****. Compression test, leak down test....etc.....baroscope.....
SimpleUser
Apr 24, 2021 02:54 AM
Civic15
18
Sep 19, 2017 07:48 PM
Green02civic
Jul 27, 2015 10:48 PM
Dani1993
Jul 24, 2015 09:02 AM
NROD315
Jul 21, 2015 07:46 PM
