Coolant Help
Old Feb 27, 2008
bbman400's Avatar
bbman400 is an unknown quantity at this point
Coolant Help
Please help guys. I have an 05 civic and my radiator is transferring all of the coolant to the overflow tank. As a result the radiator empties and the overflow tank overflows and spews out of the top. Heater stopped working but Car does not overheat. I immediately took the care to the dealership and they flushed the system and rebleed it. They scanned the ecu and found no codes. Got home and the same problem occurred. What could it be???
Old Feb 27, 2008
speedfoos's Avatar
Re: Coolant Help
Blown headgasket. Have them test the coolant for contaminants. They will probably find a carbon contaminant (exhaust) in the coolant. This happens a lot to us turbo guys. Basically you have a slight leak in the head gasket which causes the exhaust to leak into the coolant passages of the block, over-pressurizing the coolant system and causing it to blow back into the reservoir.
Drive the car at operating temperature for about 10 minutes with the reservoir almost full. Shut the car off and immediately go look and listen to the reservoir. It will probably be bubbling which is excess pressure being forced into the rezzy.
Old Feb 27, 2008
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
Re: Coolant Help
how many KMs or Miles does your car have??
Old Feb 27, 2008
bbman400's Avatar
Re: Coolant Help
my car has 42000 miles, with absolutely no modifications done to it
styles234
21
Nov 19, 2019 07:23 AM
cferry7
Oct 3, 2015 04:33 PM
raymondxcho
Sep 29, 2015 09:00 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
Bruce2
Sep 21, 2015 08:01 PM
