1987 Automatic transmission problem
Old Jan 5, 2008
19Honda87's Avatar
19Honda87 is an unknown quantity at this point
Just bought a 1987 Civic Wagon with automatic transmission. Car only has 50,000 km on it. Sat in gramma's garage for a number of years and is almost like new. Here's the issue:
Transmission does not work in reverse or overdrive. Works in 2 and 1.
When shifter placed in reverse, engine rpm drops slightly and cars moves ever so slightly, like it's trying to move. Stepping on gas to increase rpm has no effect. Exact same thing in OD position. Moving shifter further into 2 or 1 gives positive engagement and car drives in that gear without apparent issue
Any ideas?
Old Jan 9, 2008
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
Re: 1987 Automatic transmission problem
Low on transmission fluid? Cable from shifter to transmission is worn, or its an internal problem which means you're SOL.
BTW this is the 7thgen Mechanical Problems Section which means 2001-2005
cruisers10
May 12, 2015 10:46 PM
Flipg123
May 8, 2015 01:15 PM
alexkharden
Apr 23, 2015 07:13 PM
Richkid23
Apr 19, 2015 12:53 PM
Sledge
Dec 7, 2001 12:09 PM
