Help!! Sluggish Performance
Old Jul 25, 2007
jmnbv123's Avatar
jmnbv123 is an unknown quantity at this point
My car has been real sluggish in the pass year and getting worse. When i try to accellerate from dead stop it doesnt respond as quick as it us to...
Any advice would be helpful thanx
Old Jul 25, 2007
02civic21's Avatar
Ricky Bobby style, IWGF
02civic21 is a jewel in the rough02civic21 is a jewel in the rough02civic21 is a jewel in the rough
Re: Help!! Sluggish Performance
check throttle cable for granny slack if granny slack present remove granny slack.
also check the IAC valve it is located on the left side of the throttle body it is held on by three screws. remove it and clean it with TB cleaner or carb cleaner
search for the IAC valve cleaning in the DIY section for further instruction and pics
Old Jul 25, 2007
half_n_half17's Avatar
half_n_half17 is an unknown quantity at this point
When was the last time you...
1. Changed your oil
2. Changed your air intake filter
3. Changed your spark plugs
Old Jul 27, 2007
mani_is_kool's Avatar
mani_is_kool is just really nicemani_is_kool is just really nicemani_is_kool is just really nicemani_is_kool is just really nice
Bro is there a DIY for the granny slack remover too ? coz im compltetely DUMB with mechanicals and i really dont knwo where to look for that slack thing on the cable ?
Old Jul 27, 2007
Ahhh never mind :-p I found the DIY .. iHeres thelink for the TOpic maker
https://www.civicforums.com/forums/1...tle-cable.html
I cant find the link for the DIY of cleaning the IAC valves ... might be its with a different name which i dont recognize ... Please help
Old Jul 30, 2007
BLK03EX2DR's Avatar
BLK03EX2DR is an unknown quantity at this point
how many miles on the car?
First there's the basic maint items:
1. OIL!
2. Air filter element (usually every 15K or when dirty)
3. Fuel Filter (usually every 30K)
4. Spark plugs, rotor/cap (120K for platinum plugs, 60K for non)
Then there's the non regular maint items:
1. Coil
2. Fuel pump
3. Catalytic convertor (you know it's bad becuase you can't accelerate past ~35mph and the engine won't rev past 2.5K)
You can also use a carbon cleaning product. I recommend seaform marine cleaner, some swear by it others hate it. PM me if you want a rundown on how to use it. you can also go and take off the the entire intake and plenum and spray it all down with carb cleaner, let it dry, and throw it back on but that's fairly excessive. Umm yea thats all I can think of right now.
MamaBear2015
Sep 27, 2015 06:31 PM
Jrosa
Sep 14, 2015 08:24 PM
