Can Thermostat go bad, if Thermoswitch Sensor went bad?
Old Jan 21, 2007
Skydivincoastie's Avatar
Skydivincoastie is an unknown quantity at this point
Ive been having wierd overheating problems, somtimes i get no heat, somtimes i do, somtimes the temp gauge goes up, somtimes it goes down, its all messed up. I replaced my thermostat in May of 06, and the car was running GREAT untill december..it started doing what i just explained. I took it to honda, the Mech, said it was the thermoswitch sensor, located on the thermostat's housing. He sais he couldnt see any signs of a head gasket being damaged. I replaced the thermoswitch, worked fine for a few days, now its doing it all over again. My question is, can a Thermostat GO BAD from a thermoswitch going bad?
-Danny
FOR SALE!! 2002 Honda Civic EX
Old Feb 8, 2007
PaCiFiKbAllA's Avatar
PaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond repute
Bump this cause I'd like to know too!
Old Feb 9, 2007
Fueldoorfix's Avatar
Former Sponsor
Fueldoorfix is an unknown quantity at this point
A thermastat could posibbly go bad if the eng. overheated do to a faulty thermoswitch.
When you are having the problem with the heat then no heat issue. check to make sure the rad is at the top, and the overflow is up.
Your problem sounds like low coolant level in the eng.
Old Jun 11, 2009
timmystets's Avatar
timmystets is an unknown quantity at this point
Unhappy Re: Can Thermostat go bad, if Thermoswitch Sensor went bad?
-Danny
This is exactly what is happening to my 02 Civic right now.
How was it resolved? Or does anyone have ideas?
Old Jun 11, 2009
its actually called the ECT (engine coolant temp) sensor and yes its important for many different vital car functions including monitoring the temp and sending readings to the ecu. a thermostat will likely not be related to the sensor, it is just a simple wax mechanical switch that opens and closes when the temp gets hot and cold. it can only be influenced directly by the coolant temp.
Old Jun 12, 2009
timmystets's Avatar
thank you for the info
Old Jun 12, 2009
whitealexander's Avatar
whitealexander is an unknown quantity at this point
thanks for the info too..
Schneiderman
May 24, 2015 01:14 PM
Rushfan1
May 6, 2015 01:20 PM
bsmiley
Apr 27, 2015 01:27 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
01civicboi
Nov 18, 2001 04:39 PM
