Biiiiiggggg Problem
Old Nov 14, 2006
russo-r34's Avatar
russo-r34 is an unknown quantity at this point
Biiiiiggggg Problem
last nite i was driving to my boyz house and my car started over heating, i mean it took about 3 seconds to get to red line, i pulled over and blasted my A/C in case my cooling fan wasnt kicking in, i checked under the hood, and the cooling fan was working. I then checked my coolant, and its full, but looks extremely dirty. What can it be... please tell me its not my waterpump.
PS: heat in my car doesnt work - blows cold air.
Old Nov 14, 2006
01HonderCivic's Avatar
Don't be a n00b, search ftw
Uhh.....Thermostat?
Old Nov 14, 2006
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
yep or water pump....
how many miles?
year make modle.
or do you drive an R34?
Old Nov 14, 2006
russo-r34's Avatar
03 civic Si (EX in U.S.)
94 K KM
Old Nov 15, 2006
streetglower's Avatar
sounds like your thermostat. it sounds stuck closed. thus why the car overheats and why you have no heat.
Old Nov 15, 2006
AmbulanceMonkee's Avatar
I'm going with thermostat here too. Whenever I've had a water pump start to go, it leaked first. It's possible that it could fail and never leak, just seize up or something, but you would probably hear the belt on the pulley that wasn't turning. Either way, the thermostat is the cheaper fix, and the more likely problem. Definitely replace that first.
Old Nov 16, 2006
Black-EM2's Avatar
Black-EM2 is an unknown quantity at this point
and if you want to be sure...take out the thermostat and throw it in a pot of boiling water and see if it opens...simple check...but its so cheap..i would just replace it anyway.
Old Nov 16, 2006
puidokas's Avatar
puidokas is an unknown quantity at this point
^ good idea
Old Nov 17, 2006
mr.rowdy's Avatar
mr.rowdy is an unknown quantity at this point
I agree its probably the thermostat!! but if your coolant is dirty i would also be save and flush it (not hard) so that you are sure that it is not gunking up in your radiator and blocking anything.
Old Nov 17, 2006
nj_represent's Avatar
nj_represent is an unknown quantity at this point
check the thermostat anyway to verify it was that. Because if it opens, then you know you have a bigger problem.
Old Nov 20, 2006
greeen01civic4d's Avatar
thermostat then flush, flush will do nothing if you have a stuck thermostat
Diznavis
Jan 25, 2002 11:25 AM
TeamStylesRacing
Jan 20, 2002 08:38 PM
delacampos
Transmission
Jan 2, 2002 02:06 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
Flatlander
Nov 16, 2001 05:38 PM
