Pulling when accelerating PLEASE HELP
Old Nov 1, 2006
EG06KRS's Avatar
EG06KRS is an unknown quantity at this point
Aight I just got new tires on my 2001 Civic EX Coupe. I was driving and noticed that when I took my foot off the gas and let go of the stearling wheel my car would go straight, but once I put my foot on the gas it was jerk to the left. I have been experiementing with that, and noticed that it only happens when i am accelerating and once I am doing accelerating it doesn't pull anymore. And I took you alls advice and got the transmission fuild changed but it still scrapes when i shift my car into 3rd. I think my car is falling apart. Anyone HELP Please! Thanks
Old Nov 1, 2006
did you get an alignment?
Old Nov 1, 2006
EG06KRS's Avatar
No, cause it only pulls when I am accelerating
Old Nov 2, 2006
well it doesnt matter, anytime you install new tires, shocks, springs, you get an alignment.
Old Nov 2, 2006
EG06KRS's Avatar
alright I will get that done sometime over the weekend! Thanks
Old Nov 2, 2006
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
If the fluid change didn't help, then it sounds like your synchros are going bad. Well, what fluid was put into the tranny? Are you SURE they did it?
Old Nov 3, 2006
EG06KRS's Avatar
I took it to Blurington Honda which is the honda dealership, so I would think that they would not screw me ove, since they are a dealership. But I had one of my friends look at the car, turns out that the front barings from both crontroll arms are busted! So that was all that was messed up in the front. He is supposed to give me a call with the prices. I'll let yall know, just incase someone else post with this porblem. Thanks later
Old Nov 3, 2006
tfnaaf's Avatar
BLDNPSI Mod
sounds like a strong likely hood of the problem, but did it pull before the new tires? Normally an alignment wont casue a pull under accell or decell. This is usually caused from a loose part as in bushing, motor mount, and other things. Even a flat tire can sometimes cause this
Old Nov 3, 2006
EG06KRS's Avatar
I called honda and they said that is was like 400 to fix both sides give the car and alignment.
Old Nov 3, 2006
tfnaaf's Avatar
BLDNPSI Mod
They are prolly quoting 2 new lower control arms i bet.
SimpleUser
Apr 24, 2021 02:54 AM
15EXCoupe
Jul 30, 2015 12:59 PM
cyc
Jul 22, 2015 01:14 PM
wootah88
Jul 21, 2015 10:22 AM
Pwelsh
Engine start problems
Jul 9, 2015 04:15 PM
