took a sharp turn and car just died!!!
Old Oct 29, 2006
Pedro Lopes's Avatar
Pedro Lopes is an unknown quantity at this point
I was driving on the highway and then I entered an off ramp and I gave it some gas and everything was fine. At the end of the ramp where it merges into the other road the car all of the sudden died. I rolled to a stop and tried to start the engine. The car cranks over but it doesn't start what the hell could be wrong. I checked all of the fuel lines, injectors and the coil packs. The oil light came on but I just put brand new oil in it. I hope someone can help me. Thanks.
Old Oct 29, 2006
streetglower's Avatar
well if it cranks, but doesnt start, you have either a fuel related issue or ignition issue. And if the oil light came on before it died and you just changed the oil, go check the oil level to be sure.
Old Oct 29, 2006
oil or fuel starvation. dont take sharp turns. oil level is prolly low.
Old Oct 29, 2006
crazyasian's Avatar
crazyasian will become famous soon enoughcrazyasian will become famous soon enough
^wat they said. there is only one reason the oil light would come on and that would be from low oil or starvation, like gearbox said.
Old Oct 31, 2006
bump!!
Old Oct 31, 2006
Bump?????????
We told you what could be wrong. have you checked your oil level?
does the car still not start?
Old Oct 31, 2006
SOHC_VTEC_pwr's Avatar
SOHC_VTEC_pwr is an unknown quantity at this point
update!!! need more info on what you did to try to fix it.
Old Nov 1, 2006
this thread already has an answer. oil or fuel starvation. both are bad for the engine. and it happened because you were low on fuel or oil, or both.
Old Nov 3, 2006
speedingslowly's Avatar
speedingslowly will become famous soon enough
yeah that happened to my jetta after i changed the oil, and i didnt think it was the oil, because i was so used to warning lights coming on(i mean it was a VW product) and 2 weeks later i need new valves and remachining of my head. be careful!
Old Nov 4, 2006
I am working on the car right now to find out what the problem is. The car as a half a tank of gas and the oil level is good. I think it's a electrical problem and hopefully I'll find out. Thanks guys.
Old Nov 6, 2006
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
yea its the electrical problem....ummm dont know what is it called but my car died once too for no reason....and the problem turned out to be an electrical wire in the fuel sensor tank....(the unit underneath rear passenger seat that leads to the gas tank)
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
Switch BL4D3
23
Apr 24, 2015 06:57 PM
cdt12271
Apr 23, 2015 11:36 AM
twtron
Apr 17, 2015 12:09 AM
McD
Apr 16, 2015 10:46 AM
