HUGE PROBLEM - i think...
Old Sep 25, 2006
russo-r34's Avatar
russo-r34 is an unknown quantity at this point
ummm, well about three weeks ago, i driving north on DVP, going about 140, out of nowhere my car dropped RPMs to 4000 and wouldn tog past that point, i got scared cause it felt liek it seized. I went to a mechanic and it turned out that i had NO oil in my car, so i filled it and did an engine flush, my car drove well for about a week, i cheked my oil last nite cause my car started to make a knocking noise in gear, well i was out of oil again, i figured i burned my oil rings DO I HAVE TO SWAP ENGINES, OR CAN THIS BE FIXED.
Old Sep 25, 2006
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
it can always be fixed.. the question is now how much damage have you done to yer engine and how much money do you have...
might wanna bring it back to yer mechanic/dealership and have them check it out
Old Sep 26, 2006
that motor is dead, even if it works for a short while, it will die eventually. and where did the oil go?
Old Sep 26, 2006
v8eaterokv6's Avatar
i have a new home do u
how many miles are on the engine you might want to try some oild additives and see if it helps any till you can get it fixed right
Old Sep 26, 2006
puidokas's Avatar
puidokas is an unknown quantity at this point
Buy a used block, there cheap!!
Old Sep 26, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
Don't drive it, have it towed to a shop, have the compression/leakdown tested. That'll tell you the condition of the rings. If they're shot, depending on the condition of the cylinder walls, they can either be honed or bored .020 over and the motor can be rebuilt.
Driving it with no oil prolly ****ed up everything, so a total rebuild may be in order.... or find a new motor.
usajags84
May 30, 2015 06:49 PM
Ashley Farr
May 7, 2015 05:01 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
justheman
Dec 30, 2001 06:50 PM
HondaNewbie
Dec 24, 2001 12:53 AM
