Just bought a used 2004 honda civic
The car its on perfect conditions but i have some question about it.
Its this normal from factory or is something missing here?
this its the negative cable form the batery, isnt supposed to have a cover or something?
isnt this the chinese thing that you put your finget in? what is it doing here? how to remove it?
I need TP for my bunghole
Welcome
1. that is normal to have that gap
2. it is a rubb guard, you can cut it off with scissors if it bugs you
3. no it doesn't need to be covered, it is just a ground wire, but you can alway upgrade it with a grounding wire kit off ebay: http://cgi.ebay.com/ebaymotors/HONDA...QQcmdZViewItem
yup all normal. i cut my tube off with scissors carefully and upgraded all the ground wires with 4 gauge cable and gold ring terminals. the grounds on this car are very poor and only get worse over time.
Cars have a negative - ground system so the negative off the battery is sent through the chassy. That open ground wire has no danger to any open parts because anymetal part touching the chassy is negative already. However! The only thing that can short that is the positive wire off the battery.
i made my own. but its basically just 4 gauge audio wire you can get anywhere at circuit city or something and then the ring terminals. i prolly have enough supply left to make you one for around $40 shipped. or you can buy the pieces (wire, battery clamp, rings) from www.partsexpress.com
Pr0n1s
Apr 30, 2015 03:08 PM
jessicakaybby
Apr 20, 2015 12:11 PM
chgofirefighter
Apr 18, 2015 08:08 PM
