gas peddle stiff as hell
Old Jul 6, 2006
crazyasian's Avatar
crazyasian will become famous soon enoughcrazyasian will become famous soon enough
well when i was trying to install the d16y8 manifold i had to remove my stock throttle cable(the whole line which extends from the throttle body to the gas peddle). well i decided to go bak to my stock intake manifold i had to reinstall my stock throttle cable bak on but after i installed it my gas peddle is really stiff. i can hit the gas no problem but it gets really stiff or tight when i floor it to get to WOT. i left some slack in the line at the throttle body but i think i might have hooked it up wrong at the firewall. can any body tell me how to exactly attach the part that attaches to the firewall or wat other things might b causing the stiffness? thx
Cliffnotes:
gas peddle stiff as hell after reinstalling stock throttle cable line.
possibly not hooked up right at the firewall(will take a pic of this).
also had to rebend bak the bracket that holds the throttle cable but not sure if correctly bent bak(will take a pic for you guys).
aite here are the pics:
do i need to bend the bracket further left or is it fine as is?
do i need to turn that piece counter clock wise or clockwise?
Old Jul 10, 2006
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
Why did you put your stock mani back on???
I always wanted my gas pedal to be stiffer.
But every thing looks fine to me according to the pics...
i drive
Sep 14, 2015 01:56 PM
SidCivic
Sep 12, 2015 05:28 PM
JetsterDajet
Aug 15, 2015 08:07 AM
andyandyy
Aug 7, 2015 07:14 AM
fordover
Jul 11, 2015 09:10 PM
