Having overheating problems
Old Feb 27, 2006
Hawk2506's Avatar
Hawk2506 is an unknown quantity at this point
Hey, I have a honda civic 2002 lx with a whooping 525,000 miles on it. Yes this is not a misprint. All highway miles. The problems that I am having. Recently the car stated to overheat. I am losing coolant (I believe the coolant is coming out of the resouvir overflow, as everytime I drive the car was a little bit it becomes full and I have blown off the little plastic cap on the bottle before. I was having problems with my cooling fans coming on but I manually hookup those up to a switch to manual turn them on. I have no water in my oil, no white smoke coming out of my exhaust, no loss in milage, and the car is not running bad at all. I have checked for leaks and the mechanic was not able to find anything. The car only overheats after I have dive it for about 160 miles one way and then I have to add fluid to it. Also one other thing I am noticing is that while I am sitting idle or going ver low speeds I loss heat from my heater and then when I pick up speed the heat comes back. Could someone help me with this?? ANy advice would be much needed. If you need anymore infomation I would be happy to give it to you. Thanks Dax
Old Feb 27, 2006
DDragon7's Avatar
Wow, thats got to be the highest mileage 7thgen ever.
Old Feb 27, 2006
etdigitalis's Avatar
etdigitalis should not be trusted
i don't like being the bearer of bad news, but someone had problems similar to this last week (sporadic coolant spray in the engine compartment and no cabin heat at idle) and it turned out to be a blown head gasket. i'd take a good look at your oil and coolant to see if there's any cross-contamination going on... maybe even consider having your engine pressure tested.
if all that checks out, maybe consider replacing your thermostat. it could be gunked up 'causing it to stick open or closed intermittently... but that's a long shot.
i'm curious to know how many times you've done a timing belt replacement... that is typically when you'd also replace your water pump (also a cause for concern). other than that, your heater core would be the next place to look, but if you don't smell coolant in your cabin air then it's probably one of the other previously mentioned problems.
holy crap 525k miles! i'm still trying to comprehend that.
what kind of oil do you use? mobil 1?
Old Feb 27, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
crazy ... 525k miles! ... that means you drove around 130k miles a year! ... or approx 356 miles per day, every day... crazy guy ..
anyway yes ... that sounds exactly like a blown headgasket ... might want to get that checked out ...
Old Feb 27, 2006
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
holy ish thats alot of miles. Have you had any other problems besides this?
Old Feb 27, 2006
Hawk2506's Avatar
Thanks guys. I was thinking it might be a head gasket. Only thing I was wondering is how would I test the water pump? How would I tell if this was good or not?? I will change the thermostat just cause it is very easy to do. I usually drive about 500 miles a day 5 days a week. I actually have changed the timing belt about 80,000 miles ago and the water pump was changed at that time or so they say it was changed. No real other problems, i mean shocks I think are shot but with a car with that many miles I deal with it. Also this is the orginal engine just so everyone knows and I only burn a very small amount of oil in between oil changes. And other than the overheating the car runs great.
Old Feb 27, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
damn .. 500 miles a day? ...
why not just move closer to your work? ;P
Old Feb 28, 2006
Hawk2506's Avatar
I drive for a living. I deliever bank bags. So my office is my car.
Old Mar 1, 2006
Storm897's Avatar
Storm897 is an unknown quantity at this point
Have an Oil Analysis performed on your Oil. Info can be found here. I confirmed my suspicions when coolant was found in my oil through an Oil Analysis. I had no white smoke coming from my exhaust, or milky substance (coolant) on the oil cap.
Definately worth the $20.
Old Mar 1, 2006
often times a faulty radiator cap can cause head gasket like symptoms. i'm betting on the cap first.
Old Mar 2, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
oh I see .. that's interesting.
it's good you don't have a huge SUV then, huh?
Old Mar 2, 2006
dopes6070's Avatar
dopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond repute
Its really good to see this car lasting like a honda should cause after all the tranny/engine probs people have had it makes me a little nervous. Honda should use ur car in an advertisement like Toyota was doing with high meilage cars for a while. Good job on keeping the maintenence done. Sorry this is off topic but is your car an auto or manual?
Xuhme
21
Aug 7, 2023 03:40 PM
thana
Jun 15, 2020 07:05 PM
blazebrown
18
Jun 2, 2019 12:31 PM
brian257
Jun 4, 2015 08:17 PM
ttharper
May 11, 2015 07:27 PM
