parking/corner light problem
Old Jan 31, 2006
sl0wEM2's Avatar
GO LOW or GO HOME
sl0wEM2 has a spectacular aura aboutsl0wEM2 has a spectacular aura about
My car was recently in an accident and my body shop fixed it, but now my passenger corner/parking light wont turn on when the parking lights or headlights are on. but they work when hazard/turning signal is on.
Old Jan 31, 2006
might be the bulb. check that first then check to make sure three wires are connected to the socket when you pull it out. i think its the bulb. there are two filaments and one could have gotten damaged in the accident
Old Jan 31, 2006
sl0wEM2's Avatar
GO LOW or GO HOME
I dont think its the bulb because the other little bulb in the headlight doesnt work when the headlight is on either but ill check.
*edit* nevermind it was the bulb they both got damaged, thanks gearbox for the quick reply.
Old Jan 31, 2006
well checking the bulb is an easy fix. i don't know why they would play with the wires, but just look to make sure.
CarStuff
Dec 6, 2020 12:52 PM
cruisers10
May 12, 2015 10:46 PM
tylerginevan
Apr 27, 2015 12:29 PM
dooner24
Apr 14, 2015 07:51 PM
blackbullet
Dec 1, 2001 03:44 PM
