coolant issues (update on post 6)
Old Sep 28, 2005
  #31
Jrfish007's Avatar
Originally Posted by streetglower
Footnote:
One of the bigger challenges for the engineer is to design a head gasket that'll seal the aluminum head to the cast iron block. Aluminum has roughly three times the thermal expansion characteristics of iron. That makes it tougher for the head gasket to maintain a seal with all that thermal cycling than in years past with iron heads. Aluminum heads cannot withstand overheating as iron heads could in the past. It is critical to not let your engine overheat. Overheating is the No. 1 cause of scrapping an engine, not oil neglect as some people believe. Even if you don't blow a head gasket, the head may warp and cause premature wear on the valvetrain components as in some early 4-cylinder Mopar engines from the early 80s"
I think the article was talking about crysler vehicles, but should be the same for any vehicle
Honda's use aluminum head and blocks.... I thought. Should be that big a of a problem, if I'm right.
Old Sep 28, 2005
  #32
streetglower's Avatar
I am not sure. When I read the beginning of the statement, all the problems that he described was the exact same symptoms of a blown head gasket, so it could possibly help him. This one just said it was talking about crysler vehicles, but all cars should be the same when it refers to checking causes of blown headgaskets. I think.
Old Sep 28, 2005
  #33
Jrfish007's Avatar
Yeah, I know and agree, I was just mentioning that the Honda uses aluminum everything
I too think it's a blow headgasket, and yeah the symptons should be the same regardless of what the engine is made of.
Old Sep 28, 2005
  #34
Storm897's Avatar
Storm897 is an unknown quantity at this point
<removed> Same as what another person said.
Old Sep 28, 2005
  #35
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
Yep, if it's forcing the coolant out into the overflow tank, it caused by overpressure. That's a headgasket for sure.
Old Sep 29, 2005
  #36
tacheon's Avatar
tacheon is on a distinguished road
Yes. I agree. The conclusion is you have a headgasket leak which worsens as the car heats up. The coolant will be pushed into the overflow tank in an overheat situation as well, but this will only happen if your thermostat is stuck closed and/or your fans aren't functioning. Since we have eliminated those possibilities, you are only left with a headgasket leak. I believe your car is under warranty so the Honda mechanic would have to verify this with a compression test of each cylinder.
Old Sep 29, 2005
  #37
Jrfish007's Avatar
Make sure they send the heads to a machine shop to have them checked fro cracks and resurfacing, they BETTER know to do this, but you never know.
Old Sep 29, 2005
  #38
thak sucks, i bet it needs resurfacing if he's been driving it all this time.
Old Sep 29, 2005
  #39
legend921's Avatar
legend921 is an unknown quantity at this point
Bring it back to the dealer since you're still under warranty, I'm assuming.
Old Sep 29, 2005
  #40
Farage's Avatar
I like you! do you like me?
well i took the car to the dealer at 6 am. just waiting to see whats going on. i told the service rep that the level in the reserve keeps rising until it spews out the top. She said that she "never ever" heard of that happening. Then she proceeds to tell me that this may be caused by an accident i was in 3 weeks after i got the car. The hit was to the rear quarter panel and i said its impossible. she told me im being arrogant and it may be possible. I was pretty pissed and sleepy so i just went home. I hope its something with the reserve tank. Im praying its not a hg. Btw, the engine oil and coolant both look normal...
Old Sep 29, 2005
  #41
tinman's Avatar
Ummm.... Yeah... sounds like she's already trying to get out of a warranty repair. Yeah, blame it on something totally irrelevant and not in any way connected to the engine. Convince the customer that it's all HIS fault, and collect $$$.
Geez... where does Honda find these people??
Old Sep 29, 2005
  #42
Farage's Avatar
damn i just got off the phone with that biach... she says they dont see a problem and are getting one of their mechanics to drive it on the highways tonight. i said take a look at the big puddle of coolant in the engine bay. anyway she refused my request for a rental car because she doesnt see a problem yet. i also asked why she wouldnt do a pressure test or compression test first. she says they have to drive it first. i hate honda dealers with a passion.
Old Sep 29, 2005
  #43
SUPERFLY's Avatar
SUPERFLY is an unknown quantity at this point
I had the EXACT SAME PROBLEM! Stop scratching your head, it's definitely the head gasket. I took my head off myself and saw it with my own eyes. The machine shop where I went to get it ressurfaced told me the Honda dealer sends MANY heads from 01+ EX's for him to ressurface. I raised compression and gave it a port and polish job. Worst part is that it is the head surface warping and not the actual gasket letting go.
Old Sep 29, 2005
  #44
Farage's Avatar
you think its just a factory defect or because i drive too hard?
Old Sep 29, 2005
  #45
tacheon's Avatar
It is possible that the original cause was a thermostat stuck closed (originally a factory defect). That caused the initial overheat. If it was ignored and the coolant was just topped off and allowed to overheat again, it warped the engine block/head interface causing a head gasket leak. It is unlikely that driving too hard caused the headgasket leak directly as the cooling system is more than adequate.
Old Sep 30, 2005
  #46
SUPERFLY's Avatar
I should have mentionned... before removing the head I went and bought a new thermostat, removed the original one (+/-85 000 milles) and tested both. The original one was much slower to open, I replaced it. It didn't solve the problem, as I said, it was the head/gasket. But chances are the problem was created by a slow tired thermostat.
Old Sep 30, 2005
  #47
so have you heard anything from honda?
Old Sep 30, 2005
  #48
Farage's Avatar
im so pissed off. the rep calls me up early this morning and says that the mechanic took it out and it never overheated. wtf??? just because it wont overheat, they wont do the necessary tests to determine the problem. I ****in HATE the honda dealers. wtf should i do??? honestly i dont care, the car is a lease so im just gona drive it until the engine dies and then they have to replace that. idiots!
Old Sep 30, 2005
  #49
haha its a lease? who cares! just don't break it before lease is up.
Old Sep 30, 2005
  #50
best bet would be to bring it back when the problem happens, that way they will have something to work with.
Old Sep 30, 2005
  #51
tacheon's Avatar
Better yet... Since it's a lease and they're denying that it is overheating and they're incompetent at diagnosing a head gasket problem since it is intermittent, just keep driving it when it is overheating... that ought to create some obvious symptoms for the monkeys at your shop. Then you can get it towed in and confront the lady who told you nothing was wrong and create a big stink... I don't blame you for being frustrated. When people on the web in another country (I'm in Canada) can figure out a problem based on symptoms and your Honda dealer can't when the car is in front of them is pretty sad.
Old Oct 2, 2005
  #52
Farage's Avatar
thanks for all the help guys. well i have been driving the car very lightly lately. no revs above 3k and the car hasn't been overheating. however if i drive just a bit hard, it starts overheating right away. still bothers me but whatever, i guess they wanna replace an engine instead of a head gasket.
Old Oct 2, 2005
  #53
its cheaper to drop a new engine in. I saw a d17 on ebay for $200 yesterday.
Old Oct 2, 2005
  #54
Farage's Avatar
btw, some people have been telling me it may be a bad waterpump. can this be?
Old Oct 2, 2005
  #55
tacheon's Avatar
No. The waterpump is driven by your timing belt. As long as your timing belt is rotating, the waterpump is doing its job. A waterpump fails when its shaft bearing wears out and leaks, that will be evident by a squealing and antifreeze leaking at the waterpump, not by pushing coolant out and overheating.
Old Oct 2, 2005
  #56
this is kinda related, but my car makes a loud, constant squeaking noise when its raining. I thought it was a belt that was too tight but maybe its water pump?
Old Oct 2, 2005
  #57
where is the noise coming from?
Old Oct 2, 2005
  #58
the engine bay. i can't get out cause its always pouring rain. Dry weather nothing happens? meh. Started doing it after the alternator was replaced so i'm thinkin he tightened the belt too much. I sprayed dressing and it didn't help.
Old Oct 3, 2005
  #59
Farage's Avatar
btw, where is the water pump located?
Old Oct 3, 2005
  #60
it is located on the drivers side of the engine underneath the camshaft pulley. You need to remove the timing belt to get to it.
