starting trouble?
Old Mar 22, 2005
starting trouble?
Every once in a while for no reason I start the car and it cranks forever like 10 times before starting. Usually it takes 3 cranks and starts right up.
Old Mar 22, 2005
Boggie1688's Avatar
Diamond Member
Boggie1688 is an unknown quantity at this point
Yea mine does it, sometimes its when I wake up in the morning or when the car has been in a parking lot. I think it might have something to do with the cold. It seem to crank a lot then start. I dunno why it does it either.
Old Mar 22, 2005
Al Gore FTW's Avatar
jdmtytedoridori
low on gas maybe??
Old Mar 22, 2005
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
yeah that happens to me too.. i hope nothing is wrong with my car
Old Mar 22, 2005
Boggie1688's Avatar
Diamond Member
Naw not low gas, it just randomly happens...its very strange. My friend with a 03 honda accord v6 6spd sometimes has the problem too. Guess its a honda thing, maybe the supplied battery is just bearly capable?
Old Mar 22, 2005
RangerMan's Avatar
RangerMan is a jewel in the roughRangerMan is a jewel in the roughRangerMan is a jewel in the rough
yes happens with mine also from time to time on cold start...fuel pump?
Old Mar 22, 2005
flotsamm's Avatar
You sure its not the Immobilizer? Sometimes mine will crank over but not start. When it does this I look at the green Immobilizer light and usually its flashing. If it is, all I do remove the key for a few seconds then try again. I put the key in, turn it to the ACC position for a few seconds so the fuel pump can pressurize the system then it starts right up. Doesnt happen alot, but occassionally.
Old Mar 22, 2005
Rennen's Avatar
New Mod on the Block
mine does that sometimes too. i can hear the starter try to start the car but it wont. when that happens, i just take out the key and try again... it usually starts after that.
Old Mar 22, 2005
diskreet's Avatar
First thing to do is turn the key to "ON" which is one notch before start for a few secs till you hear that little buzzing stop. This way the car has time to get itself ready. then turn to "START" and you should start up faster. just calm down and you wont have any problems.
turn the key one more click to ON then after thats pressurized let it start .
Old Mar 22, 2005
realitycheck's Avatar
realitycheck is an unknown quantity at this point
My car never does that, like every time i get in my car touch it and the first time it fires up. No problem.
Old Mar 22, 2005
flotsamm's Avatar
Err.. I meant the ON position.
Old Mar 22, 2005
_Viper_'s Avatar
That is usully because of extra fuel that has not burned in the cylynder i believe my 05 does that also almost like its flooded 10 cranks and the it starts pretty normal i believe
Old Mar 22, 2005
diskreet's Avatar
lol i fixed what you said tho!
all is ok in 7gc
Old Mar 22, 2005
qfinger's Avatar
qfinger is an unknown quantity at this point
My car never does that and I live in cold Canada.
Old Mar 22, 2005
GreatWhite02's Avatar
4 cyllinders are good but 5 is better!
GreatWhite02 is an unknown quantity at this point
Mine just did it tonight when i got off work! I think it may have something to do with the temp not neccessarily cold! Mine did it when it was hot too! I think it also may have to do with how fast you turn the key in the ignition! I believe the igintion doesnt have enough time to read the microchip in the key and therefore it will only partially crank the starter i think! correct me if im wrong but right after it kept cranking and cranking and wouldnt start i pulled the key out of the ignition completely and put it back in slowly and turned the key slowly and it started up just fine!
Old Mar 23, 2005
rEkKaShInObI's Avatar
Unsalvageable
well today for me.. it was a rainy day, my friend asked me to drive her home, so we get into my car, i put the key into the ignition, and all of a sudden i lost all power. i couldnt turn on my lights, no radio, nothing. so i got a lil ticked off and confused about why my honda let me down. the odometer went crazy, everything in my car was reset, didnt get anyworse then that. after a while i got my car to start n i was off. it was just a little strange to me bout how that happend. it couldnt have been because the key was wet when i put it in, or the cold condition..
Old Mar 23, 2005
big_daddy_b_99's Avatar
big_daddy_b_99 is an unknown quantity at this point
yeah mine does every now and then. it's kinda embarassing too.
Old Mar 23, 2005
Boggie1688's Avatar
Diamond Member
Hahaha ur telling me about embarrasing, I just started driving stick...I've stalled a few times, peeled out a few times, and twice accidentally forgot to pull the parking brake...thats very embarrasing. Oh and another time I turned the ignition while the car was on, damn hondas are too quite (is that bad for the engine) .
Old Mar 23, 2005
kornsined's Avatar
mine did that today. low on gas with colder temps = condensation in my gas tank. either that or bad gas.
Old Mar 23, 2005
it's just a random occurrance I guess. Cause it's been starting fine ever since.
Old Mar 23, 2005
StreetKnight's Avatar
StreetKnight is an unknown quantity at this point
Cool duh
you need a higher crank volt battery try the optima series
Old Mar 23, 2005
Hayz's Avatar
i thought he already had that battery? and my car does it to every once and awhile too....
Old Mar 23, 2005
qfinger's Avatar
I did that when I found out the installer did not hook up the antigrind feature on my remote starter......
Old Mar 23, 2005
Boggie1688's Avatar
Diamond Member
didn't know there was an antigring...btw whats grinding?
Old Mar 24, 2005
qfinger's Avatar
^^^ Disables the starter when the car is started by the remote you can't grind the starter on a running engine.
Old Mar 24, 2005
Supermanrider's Avatar
I dont know what im talking about
Supermanrider is an unknown quantity at this point
yeah that has happened to me a couple of times when i late at ngiht when goin home from the night its happened when the temp has changed from earlier and jsut random times
Old Mar 24, 2005
doubledeuce2k2's Avatar
every honda/acura w/ an immobilizer seems to have this problem that i've seen. i remember guys bitching about it on the rsx websites too. accords. civics. i don't care about crv's or elements, but i bet tyhey have it too...
Old Mar 25, 2005
Kizuel's Avatar
Kizuel is an unknown quantity at this point
Have you guys read your Civic quick start guides, if you got one with your Civic?
It says clearly that sometimes it may take longer to start because the "engine management software is working to reduce emissions at startup."
And like some people have mentioned, you can get around this (sometimes) by turning your key to "on" for a few seconds before you start it.
Old Mar 25, 2005
037thGenEp's Avatar
037thGenEp is an unknown quantity at this point
yea it happens to me alot too havnt had it happen when its warm/hot only in the cold. In the morning when i get up for work/school ill ignition start it so i can get a nice and toasty car when i hop in and it wont start
Old Mar 28, 2005
Matulin407's Avatar
Matulin407 is an unknown quantity at this point
my starter went out at 52000miles just changed it last week, my damn flywheel is chewed up. it started doing some of the things u guys are talking about , not starting and stuff, mine started making grinding noises then eventually stopped working altogehter in a span of like 3 days.
