here we go again. b!tch wont stay in gear
clutch maybe?
sometimes the fingers on the pressure plate wear out and it will slip in certain gears..
like 2 n 4
or 1 3 5
someone i know changed out thier clutch and it got rid of the slip....
like 2 n 4
or 1 3 5
Originally Posted by Island2K2
popin outta gear in 5th and 3rd no warranty cuzz my 02 civic is 82,xxx deep
wtf am i supposed to do now?
Go to Honda n buy some transmission fluid.
You should have gotten the transmission fluid change a while ago if your at 82k mileage. Honda transmissions are weaksauce.
Originally Posted by ty.barrack
take it to Honda, or AAMCO, probably some simple fix, your tranny is from Japan it should outlast your car.
Honda blew it with the 2000 and up trannies.
JUNK!
u think its the fluid? i wont even go into 5th or reverse
You shouldve done it at 50k. Honda transmissions are weak!
It should stop the slippin.
BTW, Only 2 1/2 quarts of manual transmission oil if your car is a manual. And the other way around if your transmission is an auto.
My 2nd gear was starting to slip at sharp long turns. Now my clutch because of the nitrous.
OEM, Im just going to replace it with a new one. Exedy clutches go for like 100 a pop. I drive alot so I would hate how the organic clutches feel. I think the racing clutches are way to hard to press. I'm just going to get a lightweight flywheel and oem clutch set if I were to change it.
80 shots is not that bad.
are you crazy.
act street discs are sweet and if you get the extreme pressure palte my 2 yr old can push it in...
no to mention they last alot longer.
dont go 6 puck tho. I just installed mine and it engages way to harshly if you dont like quick engage.
http://www.advancedclutch.com/disc.asp
look at the street disc.
it is like oem with a longer lifetime and smooth shift.
Originally Posted by pon55
Check the shift cable, it may have stretched or is worn somewhere.
Also that act clutch is not that bad, but if Im gonna pay nearly 300-400 for oem like clutch than id r ather just get a racing clutch.
jbradley4809
Apr 7, 2017 04:23 AM
97-DX-Lover
Jun 14, 2015 06:07 PM
Joshh
Jun 7, 2015 03:24 PM
