exhaust headers glowing
Old Oct 3, 2004
ddevil0013's Avatar
You gotta be as blind as Anne Frank not to see that
ddevil0013 is on a distinguished road
i just put in a cai and took it around the block to test it out. i pushed it kinda hard but not too hard, shifting at 5k rpm. when i got home and popped the hood to check everything was alright, the exhaust headers were glowing bright red (stock headers). now i dunno if this is common for a civic or if i should take a look at it further...i really dunno if it's normal for it to do that. btw its a 2k1 civic lx 4d.
any help would be appreciated
Old Oct 4, 2004
xam's Avatar
xam
snooty patooty partier
xam has a spectacular aura aboutxam has a spectacular aura aboutxam has a spectacular aura about
well did u push your car like right after a cold start? usually when u run your engine hard enough at a cold start u will have unburned fuel go into the exhaust manifold and burn in your headers, hence the glowing exhaust. its a smog and pollution thing.
edit: i wouldnt worry bout it, try to start your car and go to like a drive thru and then run your engine hard after like 15 minutes of your car starting and see if it glows super red again.
Old Oct 4, 2004
ddevil0013's Avatar
nah it wasn't from cold... i drove it for about 25 mins on the freeway doing like 80- 85mph average, then i got home and it sat there for like 8 mins. then i took my friend for a quick spin around the block and showed him the huuuuuuuge jump in performance..lol. when we got back we popped the hood and so he could check it out see how it looked. the thing was glowing like a ****, right by the sensor thing. so i dunno..we'll see if it happens again
thx for the reply tho
Old Oct 4, 2004
xam's Avatar
xam
again from my knowledge sounds like u running too rich but dont worry its normal for all cars to do the "glowing" thing, plus its not like your WHOLE header is glowing sound slike just near the O2 sensor , thats normal
Old Oct 4, 2004
ddevil0013's Avatar
hey, as long as it don't blow up... lol.. thx main
Old Oct 4, 2004
I've never seen or heard of a header getting that hot. So you look through the heat shield holes and see the tubes red hot? Man that's not normal. See if the dealer says anything about it.
Old Oct 4, 2004
ddevil0013's Avatar
yep, red hot... right by the o2 sensor. i was going to touch it but i figured i better not. i just finished installing the cai like 4hrs earlier so maybe it just didnt get used to it yet. although i did follow the instructions exactly in the diy section here with the 7.5 fuse and leaving it idle and all that stuff. should i just upgrade to performance headers to be safe?
Old Oct 4, 2004
Um intake would not have any effect on the header. There is some other problem causing that, so having it checked will be the best option. You could always get the stock header coated with jet-hot, which is what I'm doing. Keeps heat in and withstands big temp gains. You prolly won't even need to put the heat shield back on. Coating looks good and keeps heat in the pipes. But find out what the problem is first. I've never seen headers get red-hot before.
I also noticed you're from arizona, so the temps are alot higher outside. Still, a red hot header will eventually deform from that much heat.
Old Oct 4, 2004
Quijano187's Avatar
The Evil Genius
Quijano187 is on a distinguished road
your civic must be no joke if your header glows red.. take a pic
Old Oct 4, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
Originally Posted by ddevil0013
yep, red hot... i was going to touch it but i figured i better not.
Old Oct 4, 2004
ddevil0013's Avatar
F^%K..this makes me mad. i just got home from work, didn't even drive on the freeway. took it easy on the engine shifting at like 3k rpm. popped the hood and the header was still glowing. not as much as before but still visible in the dark. i spit on it and it fizzled. that tells me it's hot. i have no clue what it could be. has anyone ever experienced this before??
Old Oct 4, 2004
xam's Avatar
xam
my friends and teachers say ur running too rich
Old Oct 4, 2004
ddevil0013's Avatar
how do i fix so i don't run rich anymore?
lol
Old Oct 4, 2004
get some mods that add more air? Or vafcII and turn down the fuel. Our cars run rich in stock form, so maybe yours is worse for some reason.
Old Oct 4, 2004
ddevil0013's Avatar
does anyone have a pic of the inside of the fuse box. cuz i think maybe 2 of mine were reversed. will that do anything?
Old Oct 5, 2004
xam's Avatar
xam
i dunno about that. i can try to take a pic tomorrow morning if i am awake but i got work as well, wends i will try my best to take a pic, but on a side note i dont have a cai yet. lol one thing u can do to less fuel is take it to a shop they charge like 60 bucks to do it for u. but see what u can do, try to get a diagnost
Old Oct 5, 2004
ddevil0013's Avatar
i think i got it. on the diy on this site it says to take out the FI ECU fuse (7.5amp) wait 10 mins..etc. i did that. then i looked in my manual and i saw the FI ECU fuse is not 7.5, but its the 15amp fuse right below it. the 7.5 is the "inerior lite" fuse. im guessing this is what caused me to run rich because i redid it and took it for a spin and it was fine. on the other hand tho, i couldn't resist touching the headers, therefore burning the sh*t out of my finger. lol. just curious to see if red headers are really hot headers. turns out its true. i learned a valuable lesson tonite. thx for all the info guys.
Old Oct 5, 2004
xam's Avatar
xam
omfg i used to change oil for work and i remember this guy got his arm on the header and just for a sec too. and his skin stuck on the header... really gross. lucky u man.
Old Oct 5, 2004
Wulf's Avatar
Wulf is an unknown quantity at this point
Would he be running too rich or too lean? I know on my motorcycle the header only glows hot when I am running too lean.
If you are running too rich you should actually be running cooler. This is how it works on motorcycles, and I would think it would apply to cars too. The only difference is when I open up the air intake on a motorcyel I ahve to rejet the carb to make it run richer, where the ECU should compnesate for the extra air.
Have you checked the ECU to see if it adjusting the fuel or not? If the ECU is not compensating for the extra air then you are definetely running lean. Be careful or you can burn out your pistons! Seen to many of those on cycles!
Old Oct 5, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
Old Oct 5, 2004
ddevil0013's Avatar
well good news is i think i fixed the problem by resetting the ecu so it should be adjusted to the extra airflow...bad news, my middle finger is sporting a huge bubbly blister the size of a ...size of..a...penut?? i dunno..it hurts and it's big and im poking it with a needle.
Old Oct 5, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
is it normal that I bust out laughing everytime I see a new post in this thread?
Old Oct 5, 2004
If something is glowing red, don't touch it sheesh! Anyway, a lean mixture will cause everything to run hotter. Also, resetting the ecu will erase fuel curves, but the ecu should also compensate while you drive without resetting it. That's mostly for idle problems. The o2 sensor allows for these kinds of adjustments to be made by the ecu.
Old Oct 5, 2004
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
this happens on other cars, but ive never heard of it happening on our cars, so as said earlier you might be running lean.. causing things to heat up quite a bit
Old Oct 5, 2004
gotti's Avatar
my turbo manifold gets reaaaaallllllly hot too. i dont really think it glows tho ?
Old Oct 6, 2004
ddevil0013's Avatar
ok..now it's just ridiculus. it done done it again. wtf pos civic. i put in an intake and the headers are prolly gonna blow. is there anywhere i can get a diagnostic run for cheap or should i just take it to a dealership?
Old Oct 6, 2004
ctx66's Avatar
i dont think most dealers would give you a warm welcome. theyd prolly just say its your problem since you modded it.. but i could be wrong.
Old Oct 13, 2004
2K1Civic17"Gabe's Avatar
No dealer would turn you away with cash, are you crazy? Dealers want to make as much money as they can, I doubt any dealer not on crack would turn any paying customer away?
Old Oct 13, 2004
cambo's Avatar
I wish I was asian
are you sure its hot?
maybe you could touch it again just to be sure.
Old Oct 13, 2004
ddevil0013's Avatar
it's still doing it. yea it's still hot. my finger still hurts. i've gotten used to it i guess it's just normal. i'll make sure to post when the headers start melting away. i like cheesecake.
