water in the trunk!!!...
Old Aug 14, 2004
sw388integra's Avatar
i took it to the dealership today(1000 miles left on the warranty! ) and they looked at me like i caused the problem!!! has anyone had this problem...i thought it was the seal around the top, but can't find where it would be coming from???? and with this storm around my way, it's been pouring lately!
Old Aug 15, 2004
It has to be the seal. Mine leaks water in, but only when I open it and it drips from the top
Old Aug 15, 2004
when you take all the carpeting out, there is a "vent type thing" behind it that goes through to the inner fender...the little flap opens up and leads to the outside...could that have anything to do with it?..
Old Aug 17, 2004
DrOpPeD2k2CiViC's Avatar
DrOpPeD2k2CiViC is an unknown quantity at this point
Mine does it too. Just take a water hose and look for the leak. Start from the bottom and work your way up. Once you find it feel it with some 3m or SEM seam sealer. Problem solved
Old Aug 24, 2004
Importracer's Avatar
Importracer will become famous soon enoughImportracer will become famous soon enough
okay, my car was the one that put this in the books for honda dealerships all over the country. The leak is comming from the fuel flashing inside. There is a black piece of plastic inside where the gas cap is, you need to open upthe trunk on on the side, start feeling for the fuel inlet. then use some silicone and fill that.
Old Aug 24, 2004
HappyGilmore's Avatar
HappyGilmore is an unknown quantity at this point
^^ Correct.
Old Aug 24, 2004
thanks man...the dealership basically said that it wasn't their problem and warranty wouldn't cover it...snd i saw that thing and pointed it out to them. and that's where the water has been coming in...so' i quess i'll silicone the hell out of it...thanks again...
Old Aug 25, 2004
That's funny. It's not their problem. So who's problem is it?
Old Aug 30, 2004
yea man glad i could help you...
Old Aug 30, 2004
SuperFrankie's Avatar
SuperFrankie should not be trusted
mine leaks too its through the corner of my tail light =\
Old Sep 17, 2004
wrussi's Avatar
wrussi is an unknown quantity at this point
mine did to after honda had the car for 5 days they fixed
alaga
25
Aug 13, 2015 04:42 PM
bdrickybd
Jul 25, 2015 04:35 PM
