Gas mileage?
Old Aug 1, 2004
y.0. KiLLa's Avatar
Powered by Honda
Gas mileage?
wtf! i juss put 20 dollars in my 01 civic ex..i drive 42.0 miles and its now on the half way mark..wtf is that about..n no i havent driven it hard or nething..just last week i got 205 on a full tank? whats wrong? i thought civics had great gas mileage..apparently i dunt have a civic? lol
Old Aug 1, 2004
Lol, mine's like that. In the city, it gets 22mpg. When I drive all highway, it's more like 36. I think it's all the stop/go driving that does it. Idle wastes alot of gas.
Old Aug 2, 2004
HappyGilmore's Avatar
HappyGilmore is an unknown quantity at this point
Let me get this straight...You drive 42miles after you've put in $20 gas (assuming you've top it off). Then your gas needle drops to half. Sounds like a faulty gauge, software update...
Your problem may be related to this: http://www.nhtsa.com/TSBScans/sb624366.pdf
Do a search next time. Also, here are a list of other problems.
http://www.7thgencivic.com/forums/sh...&highlight=tsb
Old Aug 2, 2004
zen_master's Avatar
no freakin way...
either your engine's dirty.....ur plugs busted....or your needle calibration is off..
mine usually about 100miles after one or two bars down...
Old Aug 2, 2004
CuRiOuSfIsH's Avatar
Back From The Banned!
are you sure there isnt a hole in your tank? My needle is whack sometimes, but it's never that off.......... IF you drove 42 miles in about 1/2 tank.... that would be... maybe 8 miles per gallon? What kind of driving.... or maybe idling were you doing? It cant be that bad unless youre idling for hours and hours.
Old Aug 2, 2004
zen_master's Avatar
is ur gas tank leaking?
Old Aug 2, 2004
y.0. KiLLa's Avatar
Powered by Honda
i dunno..wtf..this is bullshit..my dads 87 maxima (which is a gas hog) gets better gas mileage? wtf maybe my fuel guage is messed up..i dunno im juss gunna keep driving end when the fuel thingy goes to empty. im gunna see if the ligh will come on and tell me to refuel...perhaps its busted?
Old Aug 2, 2004
y.0. KiLLa's Avatar
Powered by Honda
well i dunno..i dunt really drive on the high way.i usually do stop/go driving..but i dunno..i thought it would still get better mileage..well i juss got my car a month ago..i have always noticed that im not getting gas mileage..next week im due for an oil change/tranny fluid change...maybe ill tell the dealer..wTf..im so mad..i cant believe that in like 2 days i will have to put another 20 dollars..40 dollars per week!!!
Old Aug 2, 2004
zen_master's Avatar
dood, get ur self a fuel injector cleaner...
probably u filled up a very dirty gas...from a suck-*** gas station?
Old Aug 2, 2004
StealthCivic's Avatar
StealthCivic is an unknown quantity at this point
Hey Gear,
Why is your mpg so bad man?? That sucks!
Old Aug 2, 2004
have you tried another gas station? A very small chance that the station is rigged. It maybe coincidently that you have a defective part and in addition they rigged the pump to read higher but you are not actually pumping that much.
Keep us updated then we can advise you more.
Old Aug 2, 2004
y.0. KiLLa's Avatar
Powered by Honda
ive been using that gas pump for a long time...b4 i went to the station my refuel light came on..when i refueled it went all the way past full..i drove around and then 2 days later its on half.i check the trip meter..i reset it when i refueled..read 42.0 miles..
question: does using ur ac use up ur gas 2...i havent used my ac but im asking..cuz if it does i might average 2 miles per gallon..lmao..lol
Old Aug 2, 2004
When my fuel sender broke, the fuel gauge would be below E when there was 5 gallons left in the tank.
If the poor gas mileage is actually true, you need to check plugs, oil, tire pressure, and air filter. Those are the most important.
Old Aug 2, 2004
AC does use up gas. ok, so see how it goes with this current tank of gas. If it gets to the 1/4 mark but you only fill up a few gallons, then I think you know what to do next.
Old Aug 2, 2004
The sending unit in the tank may be faulty. Have it checked since you have warranty.
Old Aug 2, 2004
y.0. KiLLa's Avatar
Powered by Honda
k thanks guys..ill keep u updated..
Old Aug 2, 2004
dirtySAMURAI's Avatar
I log in from time to time
And I thought I had it bad with my previous 18mpg. After changing my spark plugs and more tire pressure I'm averaging 25-26mpg. Every notch on the fuel guage is about 20miles for me. After half way, though, the guage will just drop down to empty. lol...crazy honda fuel guage.
Old Aug 2, 2004
yuup, after 200-230 miles, that needle just drops to less than a 1/4 the next time I start up the car.
Old Aug 2, 2004
Wolfgang5884's Avatar
ouch sorry to hear that, somthing has to be wrong....check everything u can
Old Aug 3, 2004
HEY, am I seeing double or did someone use the same avator as me! I was here 1st!!!
j/p man... haha
Old Aug 6, 2004
streetglower's Avatar
I am averaging about 290 miles to the tank now, I wish I knew the problem.
Old Aug 6, 2004
NaSh123's Avatar
NaSh123 is an unknown quantity at this point
I have a question for your guys....Lets say your going 40mph would it be better to just put it in neutral and coast or leave it in 4th or 5th gear and just give it a little gas to keep it at a constant 40mph?
SidCivic
Sep 12, 2015 05:28 PM
bsmiley
31
Sep 1, 2015 06:11 PM
mrwhos
Aug 11, 2015 02:03 AM
andyandyy
Aug 7, 2015 07:14 AM
shaejb15
Jul 27, 2015 03:48 PM
