Help...hp header problem
Old May 18, 2004
Shlomo's Avatar
Shlomo is an unknown quantity at this point
Question Help...hp header problem
Ok, here's the deal. I installed the hp header and high flow cat. with this new combo there are three holes/bungs for the oxygen sensors. Two are on the new header itself and one is on the new cat. Two of these holes are used one is not. I do not know what to put in the third hole. The owner of hp header said to use preexisting hardware but there were no bolts/screws large enough to use. So my question is to everyone that has installed this...what did you use to plug up that extra bung hole. Thank you very much.
Shlomo
Old May 19, 2004
Shlomo's Avatar
Nobody has any ideas??
Old May 19, 2004
HYPR DRV's Avatar
Since 1977
HYPR DRV will become famous soon enough
Can't you go to a hardware store and buy the right size "bung" to plug the hole? I have the same set up but don't remember encountering this problem.
Old May 19, 2004
Da1lyDr1ver's Avatar
just get a bolt that fits properly in the hole and screw it in. its really that simple.
Old May 19, 2004
Shlomo's Avatar
i've looked at pepboys, sears hardware, menards, and home depot and i have found no bolts that fit. I called hp and they said that the bolt size is 17mm, does anyone know of a store that carries bolts this large? Thanks
Old May 19, 2004
Shlomo's Avatar
hypr drv. how many "bungs" were in your header and cat that you bought?? I only have two O2 sensors but three bungs.
Old May 19, 2004
HYPR DRV's Avatar
Since 1977
Yeah, same with me. But the shop that installed my header and downpipe got it to work somehow. I also got an O2 Simulator with mine. But that just wires right into the ECU. There has to be a bolt that will fit.
Old May 19, 2004
Shlomo's Avatar
so after countless phone calls to numerous hardware stores and car parts stores i finally ended up at NAPA who said the had what i needed. When i arrived at NAPA they said they didn't have the bolt i needed. So they lied to me on the phone. I spent 1 and a half hours in NAPA waiting for the sales guy to find the right bolt. $1.29 later the bolt doesn't even fit. So hopefully after tommorow morning it will be resolved...HYPR DRV did your hp header/cat come w/ the O2 simulator and do you have a check engine light??
Old May 20, 2004
HYPR DRV's Avatar
Since 1977
I got the O2 Sim seperately so the CEL wouldn't come on after I installed the downpipe that replaces the cat.
Old May 20, 2004
Shlomo's Avatar
ok, well i finally got it to work after going to NAPA again this morning. I've been flat out lied to two times in the past 24 hours. Bad customer service. Anyways im using a 3/8 inch oil drain plug. it was a little loose going in but once in, it should be perfectly fine. Just incase anyone else has this problem. Thanks for everyones help.
Old May 20, 2004
Shlomo's Avatar
hey HYPR DRV, does your car ratttle/shake more than it used to? Also when you use your A/C does your car shake even more? Thanks, i just wanted to see if it was normal.
Old May 20, 2004
HYPR DRV's Avatar
Since 1977
^^^Uhhhh, I guess my car vibrates from the exhaust when I'm idling with the A/C on. But I wouldn't say that the car itself shakes or rattles. I didn't notice anything like that when I had my header/cat replaced. Just vibrations from the exhaust.
Old May 20, 2004
Shlomo's Avatar
Ok, well mine vibrates more w/ the new header/cat. Thanks for the response though.
Old May 20, 2004
did you shave your motor mount? if you have an manual EX you gotta shave off part of the motor mount.
Old May 21, 2004
Shlomo's Avatar
yeah, i actually removed the motor mount, installed the header and shaved some of the black metal part that was in the way of the header. I'm thinking that i might need to shave some more off. I also think i have a leak between the header and the cat. (I'm hearing two different exhaust tones) Is there supposed to be a gasket in between the two new pieces?
Old May 21, 2004
HYPR DRV's Avatar
Since 1977
Two different tones at the same time?
Old May 21, 2004
Shlomo's Avatar
yeah, like i hear one tone coming from the engine bay and another tone from the actual exhaust outlet. I'm going to check for a leak where the header and cat meet.
Old May 23, 2004
gangrel138's Avatar
gangrel138 is an unknown quantity at this point
I'm having a similar issue with my new EX header and high flow cat. I just changed mine out from the stock HX setup and discovered a gasket on the end of the stock header. Going to install it tomorrow and see if that fixes it. Not quite sure it will as I think the HX and EX may use a different gasket.
Since you have an EX check your stock header and cat(if you still have them) to see if you have the gasket. Putting that on should fix your leak.
Old May 23, 2004
Shlomo's Avatar
yeah, i looked at the old header and cat and there was nothing. Do you think i could buy one from Honda?
Old May 23, 2004
gangrel138's Avatar
I'm sure you could order one from the parts department at your dealership. Shouldn't be too expensive a part. It'll probably be $10 or less.
Old May 23, 2004
Shlomo's Avatar
so there is a gasket inbetween the stock header and stock cat?
Old May 23, 2004
gangrel138's Avatar
According to this parts site I was looking at there is. auto parts select
Haven't had a chance to put the gasket in because I slept all day.
Old May 24, 2004
Shlomo's Avatar
wow. Thanks for your help, i have to go buy one now and try to get rid of that leak.
Old Jun 4, 2004
gangrel138's Avatar
Hey. Did you ever get that gasket in? I put mine on a couple weeks ago and it made the leak stop right away.
Old Jun 4, 2004
Shlomo's Avatar
i just got it in the mail today, so i'm gonna put it on this weekend. the gasket is like a round metal piece about the diameter of an orange right?
Old Jun 4, 2004
gangrel138's Avatar
That sounds about right. Just slip it in and tighten the bolts back up and it should work fine. Remember to alternate as you are putting the bolts back on so you don't put too much pressure on one side.
Old Jun 5, 2004
Shlomo's Avatar
does your header rattle against the motor mount/frame of the car, mine does and i allready shaved some off. if so can u tell me the spots u shaved?
Old Jun 5, 2004
gangrel138's Avatar
I haven't noticed any rattling. I've heard of your problem before but can't remember what they had to shave.
Old Jun 5, 2004
Shlomo's Avatar
i shaved a little off the black metal piece of the motor mount...but i also think that the header is hitting the cross frame in the front of the engine bay, and i don't think that that is such a good idea??
Old Jun 6, 2004
gangrel138's Avatar
Not sure on that one. I haven't had that problem with my GR Motorsports header.
