Driver-side auto-Lock won't go down or up
Old Apr 24, 2004
nspice's Avatar
nspice is an unknown quantity at this point
The switch that locks and unlocks my doors won't work on the driver-side. It use to move a little, now it won't move at all. The wierd part is the passenger side works perfectly so if anyone can give input I would be much obliged.
Old Apr 25, 2004
civicstreetrcr's Avatar
civicstreetrcr is an unknown quantity at this point
yeah close your door then lock or hold your handle like if your gonna open the door then lock. if im not mistaking its a mechanism so you wont lock in your keys0
Old Apr 25, 2004
nspice's Avatar
no it locks normally but the switch won't work on the driver side
Old Apr 25, 2004
take it to honda
Old Apr 26, 2004
nivenmk1's Avatar
nivenmk1 is an unknown quantity at this point
Either that or rip the door apart and have a look at the locking mechanism... It will probably need to be replaced. Taking it to honda for the repair won't be much more expensive than buying the part and doing it yourself, and probably won't be nearly as much hastle.
Old Apr 27, 2004
YEAH BUT IF HE'S UNDER WARRANTY WHY SHOULD HE WASTE HIS MONEY.
BUT FROM MY VIEW SINCE IM A D.I.Y'ER I WOULD DO EXACTLY WHAT NIVENMK1 SAYS
Old Apr 27, 2004
skiboard's Avatar
^^ Next D.I.Y. - Turn your Caps Off
so if you lock or unlock with your driver sides switch, it doesnt lock or unlock any of the doors?(even the passenger side door?) if it locks the passengers door, there's a problem with door lock switch, but if not, it's probly the switch that's gone bad
Old Jun 18, 2004
streetglower's Avatar
Well my drivers side lock wont go up or down with the remote, only the passanger side. I have to manually lock the doors, what do you all think it is. I have checked the fuse and it is fine. I am thinking it is the actuator, but am not sure. I dont really want to take it to honda cause they will charge a lot for labor, but I am going to take my door apart tomorrow, just wondering what anyone thinks it might be, and maybe I will buy that part.
Old Jun 25, 2004
Civicccc's Avatar
Civicccc will become famous soon enoughCivicccc will become famous soon enough
I just found out that mine does not work either. Is it a common problem or is just a couple of cases? And how would you fix it?
Old Jun 25, 2004
It has happened to about halft the people on this site. Basically you have to figure out what the problem is. Test the actuator or simply look and see if anything is disconnected.
Old Jun 28, 2004
AzNxTc's Avatar
AzNxTc is an unknown quantity at this point
I have the exact same problem. when I lock my car I have to manually lock it with the key every time. The passenger door still works but the driver's side won't respond to anything. How much is the dealer gonna charge to fix that? I would expect everyone's problem to be generally the same (motor fried)...can the wire really be disconnected? I've owned my car for 3 years and 45,000 miles, I guess this is the life of the motor. Can other people with this problem post how long they've owned their cars for, etc.?
Old Jun 28, 2004
irishtemper's Avatar
irishtemper has a spectacular aura aboutirishtemper has a spectacular aura about
it's supposed to do that, like the other guy said, so you don't lock your keys in the car. You can lock it with the door closed but not open, if the door is open and the key is out of the ignition, pull the door handle on the inside and push the button down, it will lock.
Old Jun 28, 2004
ok everyone who has the door problem I am going to post a DIY to fix it in a few minutes in the tech section
Donahue
Sep 8, 2015 09:00 AM
Jwzy
Aug 24, 2015 09:35 PM
JetsterDajet
Aug 15, 2015 08:07 AM
EM_WON
Jul 22, 2015 06:49 PM
