problems with reverse
Old Sep 9, 2003
Master's Avatar
Banned by Admin
Well when I try to put my car in reverse (I have a manual by the way) sometimes the stick won't go into reverse. Sometimes I try like 5 times. When it is like that I just rev the engine a little and then it pops right into reverse anyone got any ideas?
Old Sep 9, 2003
Ronin's Avatar
Ronin is an unknown quantity at this point
After the first try, did you put it back in neutral, disengage clutch, jiggle the shifter a bit ... and try again? Cuz lots of manual cars (not just ours) have this problem... and doing what I just mentioned usually cures it.
Or did you just keep trying to jam it into reverse 5 times while keeping the clutch pressed down all the time?
Old Sep 15, 2003
EX4Dr's Avatar
EX4Dr is an unknown quantity at this point
The reason (given by Honda mechanic) is that reverse gear does not have synchros. To get it into reverse, you have to shift into any one of the forward gears then shift into reverse again. Hope this helps.
Poopies
Apr 20, 2017 11:36 PM
dbagaus
Jun 10, 2015 09:29 AM
Blazz
Jun 4, 2015 01:04 AM
Richkid23
Apr 19, 2015 12:53 PM
Russps
Nov 8, 2001 02:00 AM
