Cant Believe This!!!!!help!!!
Old Aug 6, 2003
integ108's Avatar
integ108 is on a distinguished road
ever since i owned my 2003 civic ex auto its been idling rougher in neutral than it does in drive.. i had this car brand new for 4 months already and i thought maybe it just needs to break in but for 4 months? does anyone elses civic do this......rougher idle in Neutral than Drive... your not reading this wrong!!
thanks feedback would really help..
Old Aug 6, 2003
whitedaze's Avatar
whitedaze is an unknown quantity at this point
Does it do that all the time or just when you start the car?
Old Aug 6, 2003
robbclark1's Avatar
Retired suspension supermod.
Just take it to the dealer. Unless you bought it used. It should still be under warrenty
Old Aug 6, 2003
ak's Avatar
ak
Retired Mod
ak can only hope to improve
How's the oil? My car idles pretty rough when i'm getting close to 5000 miles without an oil change.
Old Aug 6, 2003
integ108's Avatar
this idle problem im having happens regardless if the car has just been started or driven for a while... and my engine oil is fine its level and i changed it just 1.5k miles ago..iand the tranny fluid just changed 10 miles ago yes 10 miles... currently have 4k miles total on the car..i bought it brand new from the dealership... i know i should bring it to teh dealer ship but i can guarantee that they will have to probably tear into the transmission to find the problem and take forever and i hate it when my car is not with me and in the hands of someone else, who agrees??, i woulod rather ask you expert civic owners becuase we have first hand experience with our cars..thanks your respond is always welcomed
Old Aug 6, 2003
ak's Avatar
ak
Retired Mod
I don't anyone here will actually be able to help you with this problem.
Seriously, just drop it off at honda and have someone over 21 accompany you. They should give you a free loaner car for as long as they take to fix it.
Old Aug 7, 2003
flotsamm's Avatar
Sounds like it could be tranny related.. Did it idle rough before the ATF was changed? At a minimum I'd double check the ATF level per the Owners manual. When your in neutral or park, the torque converter is still spinning, just not fluid coupling the power to the tranny internals. When you put it in drive, the tranny and torque converter now have a load on it and smooths out the idle. It could a bad torque converter thats out of balance, bad ATF pump or a some other internal part. Also dont rule out a bad motor mount either, its possible.
Old Aug 7, 2003
integ108's Avatar
thanks for your feedback you really know your trannies, i think im gonna drop it off to honda some time soon
