How to Disable 2010 CIVIC
Hi, I need to disable my 2010 civic so that I can store it and nobody with keys can use it.
Why? because the scratches and dents keep accumulating.
Is there a small fuse or relay I can quickly remove and replace as needed?? What else do you recommend?
Re: How to Disable 2010 CIVIC
There are a few things you could do, I suppose. You could take out the fuse for the fuel pump or simply disconnect the battery. Perhaps some more context could help us answer your question?
Pull the starter relay...
But if you disable fuel or ignition, the car can crank all day and it won't start.
after9events
Oct 20, 2010 01:18 PM
