Brakes Post information/questions/Issues about Brakes here.
2013 civic sedan what size hose will fit the bleeder nipple?
Old Jan 26, 2020
poppa's Avatar
poppa is an unknown quantity at this point
Question 2013 civic sedan what size hose will fit the bleeder nipple?
Hello all, i am looking to make a DIY jug to bleed/change the break fluid in our 2013 Honda civic sedan and was trying to find out what size of the outer diameter of the bleeder nipple was or if anyone knows what size inner diameter hose i need to buy in order to fit snugly on the nipple(s). Are the front and rear nipples the same size? and if you can confirm the nut size is 10mm? Thank you very much in advance for any info!
John-
Old Jan 27, 2020
Colin42's Avatar
Re: 2013 civic sedan what size hose will fit the bleeder nipple?
John-
​​​​​​Rears may be an 8, just buy a set of flare wrenches.
As for the hose, the hose on my vacuum bleeder kit fit the nipples fine, the little rubber attachments that are supposed to go on the nipples were too big
Old Jan 27, 2020
poppa's Avatar
Thanks for the info!
pinehilljoe
Dec 15, 2017 05:53 PM
CivicGuy2018
15
May 25, 2012 02:09 PM
webxfx
Aug 29, 2004 12:56 PM
ZSKCivic01
Apr 14, 2002 09:04 PM
ren808
Feb 6, 2002 03:15 PM
