2014 Civic Sputter from exhaust/ 1500-2000rpm jerking
Old Sep 28, 2024
DeadlyRemains's Avatar
DeadlyRemains is an unknown quantity at this point
I have a 2014 Honda Civic Coupe 1.8l and long story short had a crack in my radiator which I thought was a tiny hole. My water temp high light came on and steam came from the intake. I let it cool down then tried to start it and it would not start the first couple tries, waited some more and it finally started and I drove it home quickly and parked it. Coolant was almost bone dry due to the 7 inch long crack in the radiator. I knew I had to buy a radiator and since the steam came from the intake I knew the gaskets were shot. Took care of the intake first and then the radiator. No coolant has mixed with oil and vice versa, no white smoke out the exhaust. Thought all was well but now have 2 other issues. 1 while idling I get these putting noises from the exhaust shown in the video below. 2 is when driving it between 1500-2000rpms the car skips/jerks until I give it more acceleration and it’s gone. Car idles fine until it putts and then it might dip very slightly then back to normal. I’ve done a lot to this car in the past several months and I’m trying really hard not to take it to the shop because I normally do all the work to my cars but I’m stumped. Any help would be much appreciated.
File Type: mov
Old Sep 30, 2024
BrotatoChip's Avatar
Super Moderator
Re: 2014 Civic Sputter from exhaust/ 1500-2000rpm jerking
Any fault codes?
Old Sep 30, 2024
Any fault codes?
No fault codes
Old Oct 1, 2024
Super Moderator
Spark plugs and ignition packs replaced? Valve adjustment?
Old Oct 1, 2024
Spark plugs and 1 coil were replaced before the radiator issue due to rpm drops, which fixed that issue. I’m assuming valve adjustment would mean taking it to a shop so no that hasn’t been done but it wasn’t doing that prior to the radiator issue.
Old Oct 1, 2024
Super Moderator
A valve lash adjustment isn't that difficult to do. Pop the valve cover off and use a set of feeler gauges to measure/adjust.
I am grasping at straws. Not sure what else to recommend.
Old Oct 1, 2024
Awesome I will definitely look into the valve adjustment then. Right?! It’s annoying asf. Thank you for the help!
Old Oct 1, 2024
I pulled the plugs and coils and took pictures.
Old Oct 2, 2024
Super Moderator
I do get suspicious of the one coil pack that's different. However, I would still expect some misfire codes.
Tyranny
Mar 2, 2022 11:10 AM
Sumeet Sahu
Oct 27, 2019 07:07 AM
liagreenhalgh92
Jul 21, 2015 01:31 PM
DParker
Jun 14, 2013 07:53 PM
Kernel55
16
May 15, 2011 02:18 PM
