07 Civic - Cooling fans not coming on
Old Nov 13, 2022
nunchucknorris's Avatar
nunchucknorris is an unknown quantity at this point
Neither cooling fan comes on - temp gauge goes up to max. Checked with OBD live data - got to 215F and no fans. I put 12v directly to fans and they run. Jumped load side of relays on both rad and ac relays and fans work, so everything down-circuit from those two relays seems OK. Jumped ECT sensors (separately) and no luck. I also tried turning on AC to force them on, but that didn't work either (to be fair, AC has not worked in some time - don't know what issue is - and it's in the 40s here rn). I also tried swapping like relays around with no success. Seems whatever the issue is, it's on the control side of things as the fans do power on from the relay socket.
Looking for any ideas on further diagnosis, or which parts to start replacing (guessing relays first?). Any help appreciated.
prplglide
Mar 12, 2017 01:36 PM
5.0Thunder
Jul 2, 2016 09:22 AM
buggerdtp
Jun 8, 2016 02:28 PM
hokiedad4
May 3, 2015 10:06 PM
Rob02Civic
Oct 10, 2014 01:58 AM
