2015 civic automatic stalls at lights.
Old Jan 4, 2020
Sisscar's Avatar
Sisscar is an unknown quantity at this point
Hi my daughters(mine) 2015 civic stalls while stopped at lights. No codes are showing, I have no clue. Anyone have this issue before?
hopefully some insight will help.
Dale
Old Jan 4, 2020
Colin42's Avatar
Re: 2015 civic automatic stalls at lights.
Battery/alternator weak?
Old Jan 4, 2020
Sisscar's Avatar
No sir. A new battery put on last year, and charging fine. Had it to garage and they are thinking fuel filter or 02 sensor. But they are only thinking.
sorry about the duplicate question new to the forum and found it hard to navigate.
Old Jan 4, 2020
Colin42's Avatar
No worries, o2 sensor would probably throw codes, fuel filter seems unlikely as well, filter is in the tank, part of the pump assembly
Old Jan 4, 2020
Sisscar's Avatar
My daughter said an error code came up. And mechanic said either fuel or O2.
thanks again.
Old Jan 4, 2020
Colin42's Avatar
Do you know what the code is?
Old Jan 4, 2020
Sisscar's Avatar
No but I will contact the mechanic Monday to see if he knows. I also read the filter or pump rarely fails.
thanks Colin.
Dale
Old Jan 8, 2020
Sisscar's Avatar
Hi Colin,
just had the car to Honda they found the pipe that holds the Mass air flow cracked. She rear ended someone in November. So going back to the body shop hoping for an adjustment. Maybe something they missed
Old Jan 8, 2020
Colin42's Avatar
That could certainly cause running problems, find out what the code is yet?
Old Jan 8, 2020
Sisscar's Avatar
No I never got the codes since she got it fixed on site. but I’m guessing it threw the maf code.
thanks for everything
Old Jan 8, 2020
Colin42's Avatar
No worries glad it's all fixed
Shepand
Oct 25, 2018 02:41 PM
SidCivic
Nov 21, 2017 11:55 AM
Cluelesswoman
Apr 15, 2017 05:46 PM
Tbonczar
Feb 22, 2016 07:38 PM
