Start only when pushing the gas pedal at crank
Old Nov 25, 2019
Mau004's Avatar
Mau004 is an unknown quantity at this point
So I got a problem with my 2015 Honda Civic, sometimes it only starts when I push down on the gas pedal. It will start up more often when it is warm, but with a little lag at the crank but sometimes it wont either. I was thinking maybe the fuel pump is going out, but not to sure. What do you guys think?
thanks in advance
Old Nov 26, 2019
mac25's Avatar
Dr Krieger of Modification
Re: Start only when pushing the gas pedal at crank
No CEL?
sure it's not battery related?
Not sure for this model but on older civics there is a green key light on the dash, which let's you know if the ECU is receiving immobilizer signal, from the key. (Find out if you have a similar light, then watch for it while starting)
qijian
28
Oct 12, 2025 03:40 PM
Pwelsh
Engine start problems
Jul 9, 2015 04:15 PM
pantdino
Nov 19, 2014 12:24 AM
instalher
Vancouver
Jan 23, 2012 03:19 PM
Boilermaker1
Jan 4, 2004 11:23 AM
