IAC Valve question
Old Jan 31, 2011
eatmyrice's Avatar
eatmyrice is an unknown quantity at this point
Exclamation IAC Valve question
I read up on my surging idle and found to clean my iacv. I removed the iac and noticed that the shaft has no play and is stuck rock solid in one position.
Is the Iac supposed to be very stiff?
JDM d15b with d16 intake
Old Jan 31, 2011
eatmyrice's Avatar
Re: IAC Valve question
Sorry if I posted in wrong section im new to forums
Old Jan 31, 2011
well it should be able to move by playing with the metal part that rotates. if its completely stuck, try spraying some carb cleaner inside. try to avoid spraying the electrical connector part. if it still stuck, you need a new one.
Old Jan 31, 2011
eatmyrice's Avatar
Thanks. I had to wrench it with pliers and wd40. I got it moving freely after 15 min but im still going to purchase a new one. The reason it was stuck and corroded was because the new jdm motor had my old intake installed which sat for a looonnngg time allowing the Iac valve to seize up.
thanks again
Rob02Civic
Sep 16, 2018 09:16 PM
mistermenphis22
Jul 13, 2015 04:43 PM
AaronSorenson
Jul 7, 2015 09:40 PM
mievil
Apr 28, 2015 11:02 PM
viper775
Dec 9, 2001 10:52 PM
