Mothers Clay Bar
Old Sep 8, 2002
LiKEaFeRiO's Avatar
Mothers Clay Bar
Ok...I searched and I didn't quite find the answer. If I am mistaken, then please feel free to flame me and direct me to a link which contains my answer. Thanks in advance.
I bought the Mothers Clay Bar Paint Saving System which comes with a clay bay, cleaner wax, and showtime instant detailer. After reading the instructions, I came to the conclusion that I don't need any other product.
But when I read all the threads, you all talk about using Meguiar's wax and other things. So my questions are:
1. Do you guys just buy the clay bar only and use other products with it? I could only find the "system" so I'm a little confused.
2. Am I good using the 3 products I bought in the set? I don't need anything else right?
Thank you!
Old Sep 8, 2002
1955's Avatar
good question,,u can use other wax if u choose but i bought mine clay bar for one reason to get rid of water spot,it works oh but i need to work it again.
Old Sep 8, 2002
neoretromax's Avatar
neoretromax is an unknown quantity at this point
yeah you got it right just use the spray lube for the clay bar, and the cleaner wax for anything leftover the claybar didnt get.
Old Sep 9, 2002
EternalVTEC's Avatar
EternalVTEC is an unknown quantity at this point
actually the wax is to seal it all up and protect it till u wax again.
Old Sep 9, 2002
2Hottie's Avatar
2Hottie is an unknown quantity at this point
Yeah, staying with a "system" whether it be Mothers' Or Meguiars' is a good choice. Another thing to keep in min dis sometimes parts of the system can be substituted IMO. For instance, I use 3M Swirl mark remover (grey bottle), the Show Car Glaze, then Gold Class wax immediately after I use a clay bar and the results are amazing...so do what works for you, the more you do it, the better the combos you will find...good luck!
2Hottie
Old Sep 9, 2002
civicdude's Avatar
I would clay the car while soaping the car down. I dont use the spray for claying, I use it as a detailer spray.
What I do is I wash the car once to get all the surface dirt off.
I then hose it off and soap down a section of the car at a time.
I go over each section with the clay, including the windows.
I then hose the car off and re soap the whole car to remove any excess clay.
I then hose the car off and dry.
After I clay the paint I usually want to nourish it. So I use either Mothers Sealer glaze or Meguires glaze.
I wipe it on in a back and forth motion and let it dry for 30 minutes. I then wipe it off in a back and forth motion.
Next I wax the whole car. let it dry to a haze and wipe it off.
To complete this process I wipe the whole car down with a microfiber towel. This will remove any haze that the wax caused and any wax you may of missed.
Old Sep 9, 2002
Quote
[hr]Originally posted by: EternalVTEC
actually the wax is to seal it all up and protect it till u wax again.[hr]
hehe i meant the cleaner part of the "cleaner wax"
Old Sep 10, 2002
Quote
[hr]hehe i meant the cleaner part of the "cleaner wax"[hr]
well, theres a difference, see, Meguiars' has a product line out that has a Cleaner(this is an after wash cleaner, i would use the clay bar after this), then there is a Polish(this gets some of the smaller stuff the soap, cleaner, and clay bar didnt get, shouldnt be much, and it also polishes to a shiny finnish), then is the wax, witch is there to seal in the shine from the polisher, and protect the finnish as well.
a lot of companies are starting to cater to the "lazier" people, that dont want to spend 10 hours to wash, apply cleaner, polish, and wax, so they combine two or three products into one, ie. "one step wash/wax" (while it does wax your car, its a very thin coat and only lasts till u wash it again. or cleaner wax, which is a combination of the first and third steps of the meguiars 3 step system. dont get me wrong theyre good products if you are just doing it between waxings, or are the kind of person that doesnt HAVE to have the show car finnish.
as for civicdude's last post, all that washing and waxing is great! Unless of course youre under a drought!
SammySC
121
Apr 7, 2017 07:43 PM
Raiool
Oct 1, 2015 10:42 AM
rovafa2002
Sep 28, 2015 06:57 PM
beanhead
Sep 24, 2015 12:04 PM
Viczhou
Sep 2, 2015 07:55 PM
