Removing Dealer Stickers
Old Jan 24, 2002
fogbow's Avatar
fogbow is an unknown quantity at this point
Just wondering whats the best way and safest way to remove the dealer stickers on the back on my car? It's not on the glass, it's on the body. I would like them removed, I bought a 16,000 buck car from them, I don't think I need to adv they're name "Jay Wolf" and have those ugly *** letters on my body. hehe
I've been told a few things but I don't want to put anything on the body of my car that I risk messing up my paint job.
Thanks,
~fog~
Old Jan 24, 2002
UncleB's Avatar
UncleB is an unknown quantity at this point
dude, just heat it up with a hair dryer and peel it off. if it leaves in residue, use some WD40 and it will come off. wash the car afterwards and you are all set.
Old Jan 24, 2002
CIVIC9782's Avatar
CIVIC9782 is an unknown quantity at this point
Or if you can be careful use a razor blade and water and scrape it off. i did and if you are careful you won't scratch anything.
Old Jan 25, 2002
civicdude's Avatar
DO NOT PUT A RAZOR BLADE TO THE PAINT OF THE CAR...WHAT ARE YOU CRAZY. Use a hairdryer or heat gun to heat the stickers up and then use your finger to peel the sticker off. You can get the glue residue off with WD40 or Aftalene, and then just wax over the spot because the wd40 or aftalene will dull the paint in that spot.
Old Jan 25, 2002
fogbow's Avatar
Ok, cool. Thanks!
Old Jan 26, 2002
CivicLX620's Avatar
CivicLX620 is an unknown quantity at this point
Yeah I work at a dealership and have to take off tons of those when we make dealer trades. Use a blow dryer and heat it up. If you are worried about being burnt you CAN use a razor blade but be really careful and just use it to peel off an edge!!! Once you get it off, if there is still sticky crap on it jus use wax and tar remover and you will be good to go
Old Jan 26, 2002
mykel115's Avatar
mykel115 is an unknown quantity at this point
Yeah Blow dryer will do. then just peel it off. Try windex or adhesive remover to remove the sticky substance then be sure to Wax it but its better to use Polish Cuz polish can clean your paint. By removing a very thin portion of the upper layer of your paint.
Old Jan 27, 2002
Amphiprion's Avatar
Amphiprion is an unknown quantity at this point
I used a blowdryer to get it started, then just peeled it right off. Easy peasy one two threezy.
Old Jan 27, 2002
Dakker's Avatar
Giggity Giggity
Dakker is an unknown quantity at this point
I used 3M adhesive remover on mine sprayed it on and with about 3 wipes it was clean, removed the wax but hey i put it back on.
Old Jan 27, 2002
fogbow's Avatar
Did it today after I washed my car. Thanks guys! Worked out will well.
Old Jan 29, 2002
BlueBullet's Avatar
BlueBullet is an unknown quantity at this point
for further referense...Wallmart sells a product called vinyl-off which eats the glue away and makes the sticker just fall off...It is completely safe on the paint just wax the area afterwards.
Old Jan 30, 2002
Mokushi's Avatar
Mokushi is an unknown quantity at this point
My friend used that Orange Solvent stuff and it took all the ugly adhesive off right away. Thank god my dealer didn't put any of his crappy decals on my car. He just puts license plate frames on, which I removed of course...
Old Jan 31, 2002
Todd1's Avatar
Todd1 is an unknown quantity at this point
cool thanks for the tip!!!!! i will take mine off tomorrow!!!!
Old Feb 10, 2002
Todd1's Avatar
i finally got around to doing it!!! it peeled right off!!! thanx for the tip everyone!!!
Old Feb 10, 2002
TexazMane's Avatar
TexazMane is an unknown quantity at this point
what I did wuz put a pan on the stove and get the water as hot as u can stand it when u stick ur hands it...take the pan outside and stick the towel in the hot water then saturate the sticker and will melt the glue right off.
Old Feb 12, 2002
Dakker's Avatar
Giggity Giggity
cool idea
Jul 12, 2015 11:54 AM
ZILLA
Air Conditioning
Jul 11, 2015 08:35 PM
OptimisticWay
Jul 10, 2015 04:31 PM
silentz
Jul 9, 2015 08:16 PM
ballmich
Jul 9, 2015 11:59 AM
