meguirs:::haze
Old Jan 5, 2002
VNlilMAN's Avatar
The Standard One
meguirs:::haze
i got the #7 and #26 but they both leave a haze thats hard to get rid of. am i using it wrong? or whats the best way to get rid of it rather then buffing it for an hour
Old Jan 7, 2002
civicdude's Avatar
When you glaze the car using #7 how do you go about doing it? I recommend applying a little amount to the whole car in a back and forth motion. Let the glaze dry for around 30 minutes before wiping it off with a clean dry terry cloth towel. It will smear a little when removing but this is ok becuase you are going to wax over it. When you wax the car, wipe the wax on in a back and forth motion and apply it to the whole car. Make sure you are doing this in a cool shaded area. You do not want the sun to be beating down on the car. Let the wax dry for a few minutes and then wipe the wax off with a different terry cloth towel. Always use a back and forth motion when applying and removing glaze and wax from the paint. If you use circular motion, you are at more of a risk of creating swirl marks. Also use different applicator pads to wipe on the glaze and the wax. Do not use the same pads because you will get a really bad chemical reaction that will be hard to remove. If you wipe off the wax and you notice that it is still leaving a haze and streaks, you can either go over the car with a MICRO FIBER towel, or re wash the car with soap and water. I would recommend the MICROFIBER towel though. It is expensive but worth the money.
